Old 01-14-2020, 06:27 PM   #1
drolston
drolston's Avatar
Default Stoplight Stall
59A/B starts easily and runs great, but for some reason takes spells where it will die when stopping. Always re-starts instantly, but it is annoying and kind of a safety hazard.
Engine is 284 with mild street cam, Offy 425 heads and Offy 3 x 2 intake. Speedway 97 carbs with choke and idle circuits only on center carb. The linkage is adjusted so that the secondaries really are closed at idle. Pretty sure I have the float levels right at half an inch.
Adjusted idle rpm to about 750. Adjusted idle jets closed to the point where idle RPM drops, and then open half a turn. Recently re-jetted all carbs from .045 to .047 to reduce overheating, but that did not improve the stalling. Ignition is Pertronix, and I have a nice big blue spark at idle.
So what should I be looking at? Check the center float again? Open the idle jets?
Old 01-14-2020, 08:43 PM   #2
paul2748
paul2748's Avatar
Default Re: Stoplight Stall
Are the idle mixture screws screwed all the way in on the outer carbs?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-14-2020, 08:56 PM   #3
Branded
Branded's Avatar
My thought is possibly float setting.
Branded is offline   Reply With Quote
Old 01-14-2020, 09:16 PM   #4
drolston
drolston's Avatar
The outer 97's are built as secondaries, with no choke and no idle circuits, and they are on progressive linkage so they do not even start to open until about half throttle. All idle tuning is done on the center carb.
Old 01-14-2020, 09:17 PM   #5
drolston
drolston's Avatar
Do you think too low, or too high? Which would cause stalling when coming to a stop?
Old 01-14-2020, 09:42 PM   #6
uncle max
uncle max's Avatar
FLOAT LEVEL should not be confused with FUEL LEVEL.
Float needs to be set 9/32", measuring down from gasket surface of bowl to the top - adjacent to the hump - on the free end of the float... Just a wee bit lower than level when looking across it. This usually gives the magic 15/32" to 1/2" FUEL LEVEL.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 01-15-2020, 12:40 PM   #7
drolston
drolston's Avatar
I will check the float again. The good thing about the Stromberg 97 is that you can pull the top off and actually measure the fuel level in the bowl with the fuel line and pump still hooked up.
Any other suspects for this problem?
Old 01-15-2020, 12:57 PM   #8
Phil Gillespie
Phil Gillespie's Avatar
The 3 items for combustion. Electrical, fuel and air.
hows the air filters, any difference if you remove air filters, any rpm increase.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 01-15-2020, 01:01 PM   #9
solidaxle
solidaxle's Avatar
Did you synchronize the carbs?
solidaxle is offline   Reply With Quote
Old 01-15-2020, 01:32 PM   #10
hook00pad
Upon re-starting, does it sound, and act rich? Black smoke? These would be symptoms of flooding due to stopping. Make sure your floats are working under fuel pressure, it could be any of the three.
hook00pad is offline   Reply With Quote
Old 01-15-2020, 01:43 PM   #11
drolston
drolston's Avatar
Not applicable. The two end carbs are completely closed at throttle off and do not even have idle fuel circuits. All idle tuning is on the center carb.
Old 01-15-2020, 01:45 PM   #12
drolston
drolston's Avatar
Starts up and runs fine after a stall. No stumbling or other indications of flooding, such as gas smell or black smoke. Fuel pressure is regulated to 2.5 psi and I have a gauge on the pump output, after the regulator.
Old 01-15-2020, 06:30 PM   #13
cadillac512
cadillac512's Avatar
Does it idle slowly,rough,or do anything odd before it dies--or just shut off instantly like you turned the key off?
I'm trying to decide whether it might be something affecting power to the coil or distributor when stopping...like a wire flexing or a switch doing something very weird.
I once fixed a complaint like this in a '60's Chevy when the small spring on the disc in the starter solenoid broke and let that disc touch the starter motor contact and the ignition resistor bypass contact simultaneously when stopping quickly. It grounded the coil to the starter brushes. WEIRD! That's not your problem of course but odd things can happen.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-15-2020, 09:10 PM   #14
Randy in ca
Randy in ca's Avatar
Checked vacuum?
Randy in ca is offline   Reply With Quote
Old 01-16-2020, 08:24 AM   #15
solidaxle
solidaxle's Avatar
You might try to isolate the problem by blocking off and disconnecting the linkage to the end carbs and run it on the center carb.
Old 01-16-2020, 04:51 PM   #16
drolston
drolston's Avatar
The end carbs are on progressive linkage and do not even start to open until about half throttle.
Old 01-16-2020, 04:55 PM   #17
drolston
drolston's Avatar
Originally Posted by Randy in ca View Post
Checked vacuum?
That will be my next action. Spray some starting ether around the carb bases and manifold to see if I get any RPM surge.
Is there a better way to check for vacuum leaks?
Old 01-16-2020, 06:39 PM   #18
solidaxle
solidaxle's Avatar
I assumed you had progressive linkage. By blocking off the end carbs you are narrowing down the search of your problem. You seem knowledgeable, just keep hammering at it. Let us know what you find.
