03-22-2017, 09:09 AM | #21 |
Re: Adjustable Lifters
I have never seen a widened gap in the miles that lead to a valve job or a complete engine overhaul. Usually the valve seat area would lower the stem narrowing the gap.Its funny that this series of post seems to favor the use of adjustables others have gone completely the other way non adjustables and grinding the stem to fit. I used adjustables on two engines in the last 30 years,the first ones were the solid adjustables that ISKY supplies with their cam kits and they seem to be okay,think some call them Ford tractor valve adjusters.The last set I didn't want to use adjustables because I heard on early Fordbarn that some were junk China made. I had this engine at a shop and they insisted on using adjustables even though I pointed out to them they had excellent equipment to grind the stems.They argued that future adjustments would be easier and timewise they did not want to spend a hlf day or more grinding . I finally agreed to just get things going but insisted that I supply the adjustables not the tractor ones they were going to use.I bought the ones from Red Hamilton when he still owned Red's and the ones he recommended. They may have been made in Australia or New Zealand,don't remember. The engine shop had a devil of a time with them,busted knuckles and busted wrenches trying to move the adjustment screw. Took them a lot longer than grinding would have taken so they said.
"Never complain,never explain"... Henry Ford II |
03-22-2017, 01:09 PM | #22 | |
I prefer adjustable as I can "dial them in" to where I want them. With non-adjustable type, you are at the mercy of the initial valve grind. Just my preference. No doubt there are as many valid reasons for going with the non-adjustable type.
03-22-2017, 02:02 PM | #23 |
But again the gap would narrow not widen at least at first with a poorly ground or non matching valve and seat.Correct?
03-22-2017, 02:08 PM | #24 | |
03-22-2017, 02:36 PM | #25 |
03-22-2017, 02:50 PM | #26 |
If original Johnson's, timing of this thread is really good for me because we're at the lifter stage of the rebuild!!! Dick. |
03-22-2017, 03:26 PM | #27 |
I took apart a supposedly very low mileage 1939 engine about 15 years ago and saw something that I still cannot figure out or have ever seen. Every valve stem end was concave,mushroom stems so quite a wide area. I do not know if they wore this way or someone did a valve job only on this engine and did this intentionally or tried facing them in a lathe and could only cut the center. I would imagine the entire stem would be hard not just the case but I don't know. The rest of the engine had never been touched and had the original steel pistons that Ford used in these 91A engines. Mayby the hardening was off and that is how they woreout.
03-22-2017, 10:28 PM | #28 |
Any thoughts on Allied adjustable lifters (for ford and mecury V8 engines)?
03-23-2017, 02:40 PM | #29 |
We use straight stem valves in all of our old Ford rebuilds. Usually they are Chevy valves which we have found more durable. This requires adjustable lifters, of course, but when we are done, all valve clearances are correct, and any noisy ones can be easily corrected.When grinding stems for clearance, it is almost impossible to not have at least one that clicks, as most old Ford mechanics can confirm.
03-23-2017, 06:16 PM | #30 |
When it came time for my rebuild, the shop asked which way to go on the lifters. They said a valve job for adjustables was $100, a stock valve job (non-adjustables) was $200. That essentially cut the cost of adjustables in half. He said no one had chosen a stock job in the last 10 years....
I will say, a stock valve job done right, with original lifters makes for one of the quietest engines ever made!
'52 F-1, EAB flathead |
03-23-2017, 07:45 PM | #31 |
Gary aka GOSFAST,
When you get time, could you post a pic of the Johnson lifters you buy by the tray? Thanks much!
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
03-24-2017, 06:21 AM | #32 | |
Thanks, Gary in N.Y. P.S. These are the brand ONLY lifters we will use on any build leaving here. The ride in my signature now has over 30,000 miles on it and no issues. After handling/selling hundreds of these we haven't had a single bad piece, that really says much about the product!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
03-24-2017, 08:00 AM | #33 |
Wait, so these original Johnsons are solids? They don't make the hollow ones any more? How are these any different from the ones that Isky sells?
03-24-2017, 09:30 AM | #34 |
To me, I think the fact that they have a long history of not losing their adjustment far outweighs other factors. But then I putt around at about 1500 rpms and consider 2500 'wound out'. Since they are solid, do the threads continue down past the bolt when bottomed out? The hollow ones I've worked with lose some of their grip as the bolt's stem enters the void as there is no longer as much interference in the threads. If the bolt's necked down portion is fairly low, then they would still hold well when jacked up for a performance cam.
03-24-2017, 01:02 PM | #35 |
the solids gary posted look like the ones on ebay marketed as being the real deal. true?
03-25-2017, 07:49 PM | #36 |
Top line 2017 lifter cat explore it a2032 is flathead #
http://hylift-johnson.com/wp-content...talog_2014.pdf R |
03-25-2017, 08:08 PM | #37 |
I have a set of adjustable lifters, but don't know if they are Johnsons. Are Johnstons marked as such, in any way? Thanks for info.
03-25-2017, 09:21 PM | #38 |
The A-2032 is all I am seeing in the catalog.
03-25-2017, 10:14 PM | #39 |
03-26-2017, 09:44 AM | #40 |
Ordered the Hylift Johnsons on 3/22 from NOPI and they arrived yesterday 3/25 by FedEx.
Part # on box is B-2032 as JSeery reported above and manufacture dates stamped on each box of 4 range from 1/26/17 to 2/21/17. Boxes say Hylift Johnson A Division of Topline Automotive, Muskegon, USA. Am a dunce at posting pictures, but think these are the modern day, "real deal". Topline Automotive website states "Made in USA". Once in my 59AB block, and fired up, will report back. Dick. |
