05-14-2016, 06:55 AM | #1 |
Cutout and thoughts
From time to time, I have had some intermittent electrical issues with my Model A. Last week, after a nice drive, the starter would spin the engine but she would not start --seemed a "no spark issue..." with the help from Mitch (thank you) he suggested testing the spark to a head nut which was OK.. She would still wish to start...
At at point, in looking at the diagram below, I removed the hot and lights from the cut out (which was a solid state cut that that I've ran for about a year... ) still no starting... So I checked the cutout and I saw what appear to be less than very high resistance, so I figured I'd try my old original relay type cut out and she started up like a champ... So, NOW for my question and if the above sound a bit confusing sorry but this issue being an intermittent issue tends to do that QUESTION: I noticed from time to time that before I start my car, the horn or light do not work... (With either cut out) that is not normal -yes? Car will start in either case... (last week was a 1st for real no spark issue). I'm wondering if the above interment issue is what has been causing me issue... Thank you.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
05-14-2016, 07:35 AM | #2 |
Re: Cutout and thoughts
Do you have modifications from a stock electric system, ----bad connections between the generator and the battery (starter switch)---do you have a fuse on the starter?----if you do look there----follow the path--gen-terminal box--ammeter--ammeter--terminal box---starter looking for loose--bad connections, does the ammeter get hot while driving, they can get internal connection problems,(I soldered the bolts to the inner workings on mine, now cool)
05-14-2016, 07:52 AM | #3 |
My electrical system is stock, last week, I took off my dash panel and check the amp meter and key switch with and Ohm meter... All the connections appeared fine and covered the open key connections screws with electrical tape.. I do not have fuse but I installed a battery cut off switch which appear fine... I will check the terminal box for bad connections..
05-14-2016, 08:37 AM | #4 |
The job of the cut out is to "cut out" the voltage from going to the generator and allow the voltage from the generator to go to the car. That's it that's all it does.
05-14-2016, 08:55 AM | #5 |
Following the diagram these cars only have a few connections and components.. An int should be pretty easy to find.. Just yesterday I had to pin out an ECM on a modern and then find the bad splice in the circuit... Prob one reason why I'm losing my hair..
The main issues are usually: Int key switch, Junct box connections, Starter mounted fuse if applicable Armored cable Ammeter connections Lower plate wire Upper plate ground Dirty points It won't take much to open things up to clean snug and tighten it all.. It's good preventative maintenance also.. As I mentioned in the other thread the car will run without the generator and cut -out installed... Tom and I also mentioned what to check for in power when the problem is occurring .... Have fun it shouldn't take long to check all the above connections.. Feel free to always pm me for a phone call if it resurfaces I would be happy to walk you through the checks |
05-14-2016, 10:39 AM | #6 |
05-15-2016, 08:05 AM | #7 | |
05-15-2016, 08:20 AM | #8 |
MSH, send me your address using the Private Message link and I will send you a copy of my book, Get A Horse. It's to keep in your car and it helps you get her back running when she stops on you. It's small and fits in a pocket. jack
05-15-2016, 09:27 AM | #9 |
05-15-2016, 09:39 AM | #10 |
Those regulators go bad also
05-15-2016, 10:26 AM | #11 |
05-15-2016, 12:53 PM | #12 |
If the contacts fail to conduct, then you can use a short jumper wire to connect across the two cutout terminals. This will conduct the output to the battery, but you must disconnect it as soon as the engine stops or the battery will drain back through the generator.
I've never had a problem with a restored original cutout. If you use a diode cutout, then be sure it has a good heat sink. |
05-15-2016, 01:24 PM | #13 |
Thanks for all of the advice... Snowing on and off today... Ugh was 81F 3 days ago...
05-16-2016, 07:26 AM | #14 | |
05-16-2016, 09:19 AM | #15 | |
Put the original back on which is original to car and were fine now. Fredski |
