03-23-2016, 02:16 PM | #21 |
Re: Preheating of the engine
Kerosene lamps and charcoal fires placed under the old Model A's.
Ån electric trouble light under a blanket too. Sounds like a recipe for disaster considering many A's drip gas and oil. |
03-23-2016, 03:40 PM | #22 |
My dad would put a corn cob on the end of a #9 wire, soak it in kerosene, light it, and hold it under the pan to warm the oil. He would then let my 9 year old brother drive the A two miles to the country school.
The car never caught fire, but my brother did run into another car putting an end to his early driving career and costing my dad a $100 fine. Practices frowned upon now were common place and not out of the ordinary back then. |
03-23-2016, 03:55 PM | #23 |
Getting clearances right to prevent wear can be a big deal for racers. One of Grumpy Jenkins books on building racing engines mentions having the race engine equipped with dry-break disconnects so that the engine could be easily spliced into the cooling system of its tow truck. Before a run they just hooked it up and let the truck bring both engines up to running temperature. I believe they also used an electric heater for the oil pan, and had a way to heat the rear end to eliminate losses to cold gear oil!
Jenkins was a mad genius who would do anything that might produce another tenth of a horsepower or keep his engines at peak function for a few more runs. I'd bet NASCAR teams have some interesting rituals along this line...main issue likely eliminating warmup wear to keep engine ring and valve sealing at peak for a few extra miles. If I had about 50 servants, maybe I'd put one to work preheating my rides... |
03-23-2016, 04:07 PM | #24 |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
03-23-2016, 04:15 PM | #25 |
Overheard an interesting conversation at the Ford dealer service dept the other day. Guy with a new Lincoln hybred said that using an Autostart to warm up his vehicle was not effective since when there is no demand for power, the engine isn't running. One of the gals there said there was a way to force the engine to run, (and warm up) but he wasn't interested in listening. He would rather complain.
03-23-2016, 04:33 PM | #26 |
So for we've learned ; The true meaning of a "trouble light " How to detect if your A or Maytag is dripping oil by waking the fire dept & not the Maytag repair man Why so many corn cobs were stolen from out houses & blankets mysteriously disappeared in cold weather Colorado's unique registration qualifications to become a barber Keep em coming |
03-23-2016, 04:48 PM | #27 |
Once, Chief put a pan of coals under the pan & got it started, then it wouldn't MOVE. He had to pour BOILING water on the brake drums/tires, as they were FROZEN tight. LOVED them damn MUDDY ROADS.
Bill W.
03-23-2016, 05:19 PM | #28 |
Like to welcome all the Siberian Russians to the forum. (drain everything preheat... I'm still laughing) I drive in winter, "A"s hate the cold and will run like crap for 5 minutes, after 5 minutes start driving, enjoy calculating the viscosity of 600 weight gear oil at minus 20 degrees. Expect tranny to start behaving like a transmission after 15 minutes. I will state that if you are ever in Antarctica in the winter with your Model A, draining the radiator and preheating oil would be necessary. After it warms it she will run fine any temperature.
03-23-2016, 06:19 PM | #29 |
I do remember on a camping trip crossing the Arizona desert in December of 1963, every night I had to drain out the radiator's water, put it in water-tight bags and put the bags in the Army Down-filled sleeping bag with me! Every morning I poured the water back into to my '28 Phaeton's radiator. Damn cold nights ! In fact even the day time temperatures were so cold we drove with our sleeping bags wrapped around us.
Those were the early days, before I had gotten side-curtains. And in fact, were a major reason to drive me to get side-curtains ! Never went back to anyplace outside warm sunny California. My Model A winter driving in California is much like Hale1776 mentions: runs like crap for the first five minutes, transmission shifts real smooth and quiet (I can shift without double-clutching) until the trans.lubricant warms up, then back to normal. |
03-23-2016, 07:09 PM | #30 |
I remember that my Dad's '55 stick shift Pontiac had to be started with the clutch in when it was near zero and would die if you didn't ease the clutch out to carve a furrow through the gear oil.
03-23-2016, 07:10 PM | #31 |
03-23-2016, 07:37 PM | #32 |
Ahh, the dreams of youth . . . .
03-23-2016, 11:06 PM | #33 | |
That being said, I do not use the block heaters on our modern vehicles and they start quite easily at temps down to -40C. Although the new ones moan and groan at -30, they are here for a short time, not a good time. The MGB and Model A are parked in a heated garage and both started easily today. |
03-23-2016, 11:15 PM | #34 | |
03-24-2016, 12:01 AM | #35 |
The magnetic Block heater is a simple part solution. Not perfect but a good easy start! A step up from the blanket and light bulb that worked well for decades ! Wayne
03-24-2016, 05:22 AM | #36 |
The charcoal and kerosene fires under the oil pan are a hassle. Getting up early to start the fires and wait for the oil to warm is a pain.
In the mountains west of Denver 55 years ago I just placed an empty gallon anti freeze can with light bulb socket mounted inside under the oil pan. Set the can on top of a brick up tight against the oil pan. Put an other under the tranny. Cut the can in a shape so that less of the heat could escape. I used a 150 watt bulb unless it was really cold, then a 200 Watt bulb usually did the trick. I know that does not work if there is no electricity! In that case I had a Primus gasoline one burner, back pack stove that I put inside the antifreeze can. In Michigan we walked a mile to K thru 5th grade school and a mile back home ... it was really hard because it was uphill BOTH ways. |
03-24-2016, 06:57 AM | #37 | |
03-24-2016, 10:19 AM | #38 | |
Bill W.
03-24-2016, 08:58 PM | #39 | |
Fire under the hood and caused considerable damage.this was back in the day 1959. Fredski |
03-24-2016, 10:02 PM | #40 |
Geez, I'm sure glad I live in Southern California. The temperature rarely gets below 50 degrees in the winter time.
Jeff "Hollywood" Gallagher Sgt. E-4, USAF '72-'76 Honorably Discharged, Honored to Serve |
