Old 05-22-2019, 01:17 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Crab Dustributor Question
What is the grease that is used for the felt plunger that leans on the distributor disk within the crab?
Thanks ....
TomT/Williamsburg is offline   Reply With Quote
Old 05-22-2019, 02:13 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Crab Dustributor Question
Tom, I use mobil one wheel bearing grease (red) on piston and leather . Seems to work well and last a log time......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 05-22-2019, 08:17 PM   #3
TomT/Williamsburg
Thanks, Jim!
Old 05-22-2019, 09:09 PM   #4
Russ/40
Russ/40's Avatar
The plunger needs a leather disc. I don't use any lubricant. The high polish on the edge of the weight plate doesn't need any lube.
Russ/40 is offline   Reply With Quote
