Old 01-14-2020, 11:20 PM   #1
Conaway2
Conaway2's Avatar
Default Front generator bearing screeching.....
In the 50+ years I have owned this Model A, this is the first time I’ve encountered a generator bearing issue. I’ve ordered both a front bearing and bushing, as I’m not sure which will be needed. This is the original 1930 generator (I guess I really don’t know this, as I’m the 4th owner of this car....).
Any guidance in advance will be greatly appreciated !
thanks - Jim
Conaway2 is offline   Reply With Quote
Old 01-15-2020, 01:42 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Front generator bearing screeching.....
Have you ever lubricated the bearings as specified in the owners instruction book?
Old 01-15-2020, 07:37 AM   #3
Conaway2
Conaway2's Avatar
Yes - I’ve always oiled both bearings every 1000 miles or so. The generator was rebuilt by a local automotive electrical shop in the early 70’s, and I‘ve had no trouble until now, but I am now driving the car a good bit more.
Old 01-15-2020, 08:35 AM   #4
rocket1
I had a problem with the front bearing of my generator screeching,it turned out that the bearing was spinning in the housing.I put 3 punch marks in the outside of the housing so the bearing would be a light press fit and the problem was solved.
rocket1 is offline   Reply With Quote
Old 01-15-2020, 10:01 AM   #5
whirnot
whirnot's Avatar
As long as it's been since a rebuild, I would give it all a real good inspection. It may be time again. If you are not comfortable with rebuilding, Berts has some nice rebuilts.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-15-2020, 11:00 AM   #6
Conaway2
Conaway2's Avatar
thanks to a for the responses. I’ll probably pull the generator our today or tomorrow to take a look at the bearing.
Jim
Old 01-15-2020, 12:30 PM   #7
Ed in Maine
You might consider and sealed bearing in the front. That's what they use in modern alternators. After it is back together you can't see it and you don't have to lube. As an example consider a Federal 1203LL but there are many others. Ed
Old 01-15-2020, 02:07 PM   #8
VinceBlack
A bearing will make a grinding noise, squealing could mean a belt slipping, a little wd40 on belt while running will tell you. Wd40 will not make belt slip,but if noise goes away, the belt could be the problem. Seen it many times on other vehicles.
VinceBlack is offline   Reply With Quote
Old 01-15-2020, 03:23 PM   #9
Conaway2
Conaway2's Avatar
Removed the generator earlier today and cannot remove the fron bearing from the shaft. I’ve taken the C-retainer ring off, but the spacer and bearing will not budge when I put a puller on them. What’s the best way to remove the bearing ??
Thanks - Jim
