Old 01-20-2016, 09:39 PM   #1
leadpot
leadpot's Avatar
Default Dash Camera
Have been thinking about getting a dash cam for my every day vehicle. Would also like to use it in my 29 tudor. Trying to find one that has its own battery power. Ones I have looked at operate strictly off the vehicles 12v and of course the A is 6v. Any suggestions?
leadpot is offline   Reply With Quote
Old 01-20-2016, 09:58 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Dash Camera
You could get a 6v to 12v converter...
Old 01-20-2016, 10:33 PM   #3
Larry Jenkins
Make a dash stand for your hand-held camera.. Would be interested in knowing why you want one..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 01-20-2016, 10:39 PM   #4
Gary WA
Gary WA's Avatar
Go-Pro camera for your Model A and others.
www.whidbeymodelaclub.com
Old 01-20-2016, 11:02 PM   #5
denis4x4
denis4x4's Avatar
I have GoPro mounts in my roadster, pickup and motor home. Battery life sucks, so I use a plug in adaptor with a UBS port. You can use an iPad or iPhone as a moniter to set up shots.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-20-2016, 11:03 PM   #6
P.S.
Here is the one I use in the Model A. It has its own built-in rechargeable battery.
http://www.copper.com/cart/HD-DVR-Portable-DVR?
FYI.. If you have some time to kill, go on YouTube and look up Russian dashcam videos. Wow.
P.S. is offline   Reply With Quote
Old 01-21-2016, 05:02 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Here is what I recently bought, and it was only 2 bucks delivered to my mailbox. It comes in a nice plastic insulated case, so you don't have to worry about mixing up polarity if you mount it to something in the car. Just run the + to the center terminal and - to the ground side of the plug.
Those 2 spring ground clips are the negative side, but only one of them is wired to supply power, so if you solder or clip onto one be sure it's the correct one.
My GPS works great with 6 volts supplying the power, and the USB port on this should work fine to supply your camera power.
http://www.ebay.com/itm/281840953203...%3AMEBIDX%3AIT
Old 01-21-2016, 07:24 AM   #8
2manycars
2manycars's Avatar
I just bought a Nilox Mini F Wi-Fi camera. It came with some brackets for mounting, and has a removable rechargeable battery, and accepts up to 32 gig of memory. So far, so good.
http://www.nilox.com/en/camcorders/m...-fi-action-cam
2manycars is offline   Reply With Quote
Old 01-21-2016, 08:34 AM   #9
JohnLaVoy
JohnLaVoy's Avatar
I've been using the GoPro for about a year now it works well but I do carry a couple of extra batteries.
JohnLaVoy is offline   Reply With Quote
Old 01-21-2016, 08:59 AM   #10
leadpot
leadpot's Avatar
Thanks, some good ideas, am going to check them out.
Old 01-21-2016, 09:09 AM   #11
Jon W
Jon W's Avatar
We have a very expensive RV and have had a dash cam for years for liability protection. It is no longer a question of if we need a dash cam, it is now a question of which one.
Society has created a need where none previously existed. After a couple of incidents, one being a driver who tried to get rear ended, presumably for insurance purposes, and several near accidents in which cars pulled in too close and removed our needed stopping distance we realized our best protection is a video of what happened.
We also never locked our house, but now we lock, alarm and video all that happens around it because society has changed.
1928 Model A Phaeton
Knoxville, TN 37914
Jon W is offline   Reply With Quote
Old 01-21-2016, 11:43 AM   #12
Cool Hand Lurker
Cool Hand Lurker's Avatar
Tom, just to be clear, are you saying that these converter/power supply units will work on either 6V or 12V input and still provide 12V or 5V output?
If so, that is great! We have a summer car show in New Ulm that sets up a drive-in movie the night before and transmits the sound by FM radio. Your unit would let me power a good 12V FM receiver in the Model A while watching a good old car movie. Thanks!
Cool Hand Lurker is offline   Reply With Quote
Old 01-21-2016, 12:38 PM   #13
Tom Wesenberg
The lighter sockets will be the same voltage that goes into the unit, either 6 volts in and 6 volts out, or 12 volts in and 12 volts out, but the voltage reducers used with GPS and cellphones cuts the input voltage to 5 volts, so they still work fine with either 6 or 12 volts feeding the unit.
The USB port is 5 volts out whether you feed 6 volts or 12 volts into the unit, because it has it's own reduction circuit built into the $2 unit.
Old 01-21-2016, 10:43 PM   #14
old car guy
As to why you would want one if you drive in a major city it certainly nice to be able to have a record of what you see and what's going on . I have one one the front of my new ford transit and also one facing the rear. And when I crank up so do they. And it's amazing sometime what you see that you can come home and pull the cards and show the wife. I just had a fool cut me off and I had to power brake to keep from wiping him out.and after all of that he flipped me off and that was after he cut in to my lane from three lanes over. I have them on all of my cars and I hope we never need the chip to use in a court room setting but good video tells a thousand words.
old car guy
old car guy is offline   Reply With Quote
Old 01-21-2016, 10:54 PM   #15
Tiny
Tiny's Avatar
I wish I had one when I was leading a tour back in the fall when a mountain lion ran across the road in front of me.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 01-22-2016, 12:48 PM   #16
Ted Duke
Tiny,
I can sympathize. Going east on I-64 in West Virginia about 3 am in heavy rain, my wife saw a mountain lion heading west. No one believes her except me, although people see them in Virginia and WV occasionally. The wildlife people say "NO." BUT, they said the same about Coyotes until now they are everywhere... imported by the wildlife folks???
Ted Duke is offline   Reply With Quote
Old 01-22-2016, 02:19 PM   #17
Tiny
Tiny's Avatar
Ted,
The guy behind me saw something run across the road he just couldn't tell what it was. I could, it was a LION for sure. A young one but I know one when I see one.
Blackwall Panthers
Nor Cal chapter
Old 01-22-2016, 03:32 PM   #18
Houdini
Houdini's Avatar
Here is my suggestion. Get a camera that is called the Mobius. It's inexpensive compared to the Go Pro and is a high quality camera, and has a self contained battery, but battery life isn't real long, so an auxiliary battery would be needed.
Here is a link to the RC (radio control website) where these guys have become experts using this camera for their aircraft. In fact, they have worked with the developer to bring this current camera to its great specs.
http://www.rcgroups.com/forums/showthread.php?t=1904559
If you do buy this camera, you will want to reference this website for lots of good info, plus free software to really automate setting for the camera. I have one and I'm impressed with it. The former camera that this group used was commonly referred to as the key chain camera, but for the purpose you stated, the Mobius is the way to go.
The camera uses a micro HDMI card, and can be set to loop when its full, or stop when its full. The camera even works well at night when driving. Check out YouTube for Mobius videos.
Buy only from the sellers that are associated with the manufacture, which are listed on the website I mentioned above.. They are trusted vendor and will sell you the real thing, not a fake.
The camera comes with a slip on mount that has a threaded 1/4 tripod adapter, or anything else that uses a 1/4 mount. There is a suction cup mount that can be purchased separately and its really inexpensive.
For use in the car, what I do, is use a USB cable, and plug the cable into a USB 5V car adapter. These can also be bought cheap off the web, but I think those adapters only work on 12 negative ground. But for your modern car, that will work. Then if you A is 6v, the next easiest way to power the camera for longer periods than the internal battery is to get a USB battery pack. they come in different size capacities, but you won't need a real large one for this application. You will need to recharge the battery pack in the house.
The camera interfaces to your computer via a USB cable.
I bought mine on Ebay from one of the two recommended dealers in China. I just searched ebay for the word Mobius and the first one that came up was one of the recommended dealers, something like Electoponline... and it was for $68 with free shipping. These same dealers also sell the suction cup mount.
Again, be aware of those selling for less, it may not be the same product but a knock off.
Disclaimer: I have not read through the latest posts on the website above, so things may have changed or there may be new models out now.
The group is a RC group and encourages people to first look at existing posts before asking questions, especially the common ones that have been asked over and over again. Read the first set of posts that they list, as those are kept up to date and answer a lot of question you might have and need to know about this camera. Also because they are an RC group and not a Mobius camera group, alternate applications outside of RC stuff are not appreciated by this group. Questions directly related to the camera are fine. So don't ask them about Model A 6V applications, you're likely to not get a friendly response. Just saying (as I'm not a RCers, but found this website really helpful).
Houdini is offline   Reply With Quote
Old 01-22-2016, 03:42 PM   #19
Pinesdune
Pinesdune's Avatar
Another place to look is motorcycle websites like Revzilla, Canada's Motorcycle, JP cycles. They have tons of mounts and cameras, not to mention user reveiws.
Pinesdune is offline   Reply With Quote
Old 01-22-2016, 03:46 PM   #20
Houdini
Houdini's Avatar
More Mobius info:
I see from looking further that there is a new model of Mobius with a wider angle lens. Mine camera is a couple of years old now, but I find the lens I have is wide enough.
Also you can set the camera to record when external power is applied and stop when that power is removed. That is the way to go for using it as a dash camera.
You can also set it to record when motion is detected, so it could be used as a security camera in a room etc when there normally isn't movement, or in a hotel room etc. But I found that it still draws the same battery power when in this mode, so again, auxiliary batter power would be needed for longer periods, or a USB wall adater.
