08-26-2019, 05:05 PM | #1 |
Sanity check 39 rear brakes
Hi guys
In the 5-6 years since the purchase of my 39 coupe, I’ve put about 12k miles on it. I’m thinking I would like to adjust the rear brakes (front are disc). Am I correct, this adjustment is all done with the upper bolt shown in pic? Also am I correct that (with emergency brake off) I would tighten one side till I can’t turn wheel then back off till I can turn - then repeat procedure on the other shoe (same wheel)?
Thanks Andy 1952 F1 |
08-26-2019, 07:02 PM | #2 |
Re: Sanity check 39 rear brakes
Andy...Click the link below for a comprehensive "how to" on adjusting '39 thru '41 brakes the correct way. DD
http://www.btc-bci.com/~billben/brakeadj |
08-26-2019, 07:20 PM | #3 |
VIDEO - How To Adjust Early Ford Hydraulic Brakes with Wide 5 Drums > https://www.youtube.com/watch?v=Jn_XofkYjLc
08-26-2019, 07:21 PM | #4 |
DD thanks hope all is well.
this is the part I (red) believe is what I was referring to;
08-26-2019, 07:37 PM | #5 | |
08-28-2019, 06:08 PM | #6 |
Ok adjusted brakes with assist from video. Went well... Follow up question. While up on lift and examining lower brake pins I noticed that the front shoe driver side pin/dot (see attached) was facing in. In reading directions, this position for starting adjustment process. Is this an indication shoe is not centered properly?
08-29-2019, 11:01 AM | #7 |
It might mean that shoe is very thick and is fully adjusted at that point. Or, it could be wrong, but if it stops nicely I'd leave it as-is. Check them again in a year.
08-29-2019, 03:25 PM | #8 |
Brakes should not be adjusted with the shoe mounting bolts. Use the eccentric adjusters lower on the backing plate, the ones with the 11/16 heads. As you have a combination of disc and shoe brakes, I assume you have a proportioning valve between the front and rear brakes, and hopefully a dual master cylinder for safety.
08-29-2019, 05:38 PM | #9 | |
