08-24-2019, 01:57 PM | #1 |
1932 V-8 early engine steady rod brackets
I have a 32 B Pickup with a 36 V8 in it. The center crossmember looks to be an early version. It only has the outer 4 cylinder rod mounting holes and nothing for a 8 cylinder. It also doesn’t have the K legs either. Can anyone please post pictures of the steady rods installed on a V-8 with the early brackets I have pictures of? Thanks
08-24-2019, 01:59 PM | #2 |
Re: 1932 V-8 early engine steady rod brackets
This is a loose crossmember I have with both sets of holes
08-24-2019, 05:35 PM | #3 |
With your cross member you cannot attach steady rods directly without adding the inner mounting holes with any flathead V8 except the initial '32 version, the so-called flange block, where like with a four-cylinder engine, separate brackets were bolted to the sides of the bell housing for the steady rods. Those are the large ones in your photo. My second photo shows the early bracket attached to a flange block (there are no legs on the center cross member of the car in the photo). The smaller set of brackets in your photo were the second version used with flange block V8s with the inner pairs of holes in the center cross member for the rods. Last edited by DavidG; 08-24-2019 at 06:39 PM. |
