06-21-2018, 08:13 PM | #1 |
filler tube???
Guys, what gives with this filler tube near the front of the intake. I've never seen anything like this.
06-21-2018, 08:19 PM | #2 |
Re: filler tube???
That's a new one on me.
06-21-2018, 08:31 PM | #3 |
Re: filler tube???
Didn't COEs have an oil filler tube up front like that?
Alan |
06-21-2018, 08:36 PM | #4 |
Re: filler tube???
Or for a rear engine bus where the engine is mounted backwards. Would make it a little easier to add oil .
06-21-2018, 10:07 PM | #5 |
Re: filler tube???
I think it's a Canadian intake manifold....
1947 Mercury One ton Pick up truck Only produced in Canada.
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 06-21-2018 at 11:51 PM. |
06-22-2018, 01:01 AM | #6 |
Re: filler tube???
Ps: we never got the 41/42 cars, being a "British Empire" country in those days FOMOCO NZ had switched to war production by then, but as V8COOPMAN says in the later post, the alloy manifolds on the cars I have owned are marked with the 1941 production numbers he has quoted. GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" Last edited by Graeme / New Zealand; 06-22-2018 at 01:35 PM. |
06-22-2018, 02:39 AM | #7 |
Re: filler tube???
Grame and petehoovie are correct. Not that my confirmation matters.
06-22-2018, 08:23 AM | #8 | |
Re: filler tube???
As noted previously, Canadian production. Used on all Canadian-built V8s between '41 and '48. Part C11A 6520. I have a NOS example in my stash that I got many years ago from a guy in Wisconsin. DD |
06-22-2018, 09:06 AM | #9 |
Re: filler tube???
V8: Thanks for posting that photo. I never saw one before.
06-22-2018, 10:24 AM | #10 |
Re: filler tube???
Guys, thanks much...
06-22-2018, 06:43 PM | #11 |
Re: filler tube???
There is also one on the pickup I recently got from Canada. When I first saw it, I assumed it probably was for a larger truck so a person would not have to reach over the top of a high fender to add oil especially if he was a "shorty" sort of fellow ? One more problem was the former owner added an alternator which has a larger OD case. Bracket was not seated correctly in the front of Intake. I pulled the filler pipe out so the alternator would be sure to seat right and then reinstalled the tube . You might put a hair between them if you took it from a bald guy !
06-22-2018, 09:43 PM | #12 | |
Re: filler tube???
Alan |
06-23-2018, 01:13 AM | #13 |
Re: filler tube???
Just when you think you don't know about flatheads, this one comes along and confirms it.
06-23-2018, 08:55 AM | #14 |
Re: filler tube???
Quite the dichotomy. If the guy is bald there is no hair to take.
