01-29-2018, 09:07 PM | #1 |
Filler Material
I have read of a product which can be used to fill screw holes that have stripped out and then re-drill the hole.
Has anyone used such a product and does it work WELL? |
01-29-2018, 09:26 PM | #2 |
Re: Filler Material
JB Weld
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
01-29-2018, 09:26 PM | #3 |
Re: Filler Material
I have uesd toothpicks and glue for small holes ---worked on golf carts, have a lot of golf tees ----sand to size and glue
for quick I have cut off 1 leg of cotterpin, stuck in hole, 1/2 of bent top digs in ---twigs, wire,epoxy, bondo ----much depends on how quick, how pretty, how strong |
01-29-2018, 09:41 PM | #4 |
Re: Filler Material
Drill it out, glue in a wood dowel & start over.
Bill Drill
01-29-2018, 10:49 PM | #5 |
Re: Filler Material
Depends on the material type that the hole is in.
Many options are available, from fillers to Heli-Coil type inserts. What is the hole in? What type of threads (wood, machine, etc)?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
01-29-2018, 10:54 PM | #6 |
Re: Filler Material
01-29-2018, 11:15 PM | #7 |
Re: Filler Material
Thanks all for your comments and suggestions.
1930 The material is wood. The stripped out holes are from wood screws that hold the panel inside the door itself which holds the window crank. I was actually looking to find a product similar to JD weld but know that was not it. |
01-29-2018, 11:37 PM | #8 | |
Re: Filler Material
http://kwikpolyllc.com/
01-30-2018, 06:28 AM | #9 | |
Re: Filler Material
John |
01-30-2018, 09:39 AM | #10 |
Re: Filler Material
What Bill said post #4
01-30-2018, 10:50 AM | #11 |
Re: Filler Material
If it in wood the drilling out and replacing with a hard wood dowel especially the ones with the spiral cuts up the sides hold great. These type of dowels were used in the corners of cabinet doors between the rails and styles. Smaller holes just a small dowel or tooth pick will work.
01-31-2018, 02:06 AM | #12 |
Re: Filler Material
01-31-2018, 02:55 AM | #13 |
Re: Filler Material
If you are talking wood work, there is a 'plastic' wood filler that has the qualities that you may want.
01-31-2018, 03:51 AM | #14 | |
Re: Filler Material
01-31-2018, 11:16 AM | #15 | |
Re: Filler Material
" The Woodmate Mr. Grip Screw Hole Repair Kits can be used to fix old worn and stripped screw holes. It doesn’t even matter what material the screw is embedded in - wooden, metal, plastic , even cement, aluminum or anywhere screw holes need fixing. To use simply cut a strip to the size needed, fit it lengthwise into hole, insert a screw and tighten. And not to worry, if you make a mistake with this product its ok, a screw may be unscrewed if needed." Last edited by Y-Blockhead; 01-31-2018 at 11:28 AM. |
01-31-2018, 02:43 PM | #16 | |
Re: Filler Material
1929 Model AA - Need long splash aprons! |
