Old 11-11-2019, 08:12 AM   #41
Tim Ayers
Default Re: 32 axle bent twist ?
Originally Posted by Krylon32 View Post
I had a 32 axle that resembled yours many years ago, I had it straightened and dropped by Anson Axles. He did an excellent job. He also repaired a couple 32 axles for me without dropping them.
Greg is great. Depending where the OP's is located, Andy Kohler in Williamsport, PA can do it as well.
I just shipped a '32 axle to Greg and was dumbfounded when it cost $50 to ship it to his business. Round trip would have been $100. Outrageous.
Old 11-11-2019, 04:34 PM   #42
rust revival
Ok, Thanks again everyone for the tremendous help Looks like I got the wishbone were it should be , and axle will be shipped out
Now I’m getting a little ahead of myself,
but
I don’t see a recommendation for torque on the perch pin castle nut what is everyone setting them at ?
rust revival is offline   Reply With Quote
Old 11-11-2019, 04:41 PM   #43
Mart
Mart's Avatar
As tight as you can, bearing in mind you want to end up with a split pin hole lining up. 100lbs ft plus. (I don't use a figure, just v. tight with a 30" bar.)
Old 11-11-2019, 06:45 PM   #44
Tony, NY
If you have a gap between the wishbone mount to the axle, it can be shimmed.
Tony, NY is offline   Reply With Quote
Thread Tools
Display Modes
