11-15-2019, 06:10 PM | #1 |
36 Ford PU shock mount mod to 2" body drop
Has anyone come up with a good modification to the front upper shock mounts to allow use of same shock with 2" body drop with extended shackles?
11-15-2019, 06:38 PM | #2 |
Re: 36 Ford PU shock mount mod to 2" body drop
are you talking about aftermarket conversions (tube shocks)?
11-15-2019, 08:07 PM | #3 |
yes
11-15-2019, 08:27 PM | #4 |
Using longer shackles to lower an early model (pre 40) can be problematic. The angle and length of the shackles help control side sway. Longer shackles require the use of a pan or sway bar.
11-16-2019, 11:16 AM | #5 |
