Old 11-06-2019, 07:19 PM   #1
Stretch Cab
Stretch Cab's Avatar
Default Drag Link Rebuild?
What do I do with the end of the drag link that has the tie rod type end seemingly permanently attached? Can that end be rebuilt? I do not see any rebuild kits for doing the rebuild but I do see the option for buying a new one for over one hundred dollars. The one I have is from a low mile car but it is still 83 years old.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 11-06-2019, 07:22 PM   #2
mfagan
mfagan's Avatar
Default Re: Drag Link Rebuild?
There is a kit with a new spring and cup . I have one I never used.
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 11-06-2019, 07:33 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Is it like the TOP one in the picture? If so, I've never seen them being rebuilt. Just gotta step-up and pull your wallet out. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-06-2019, 08:24 PM   #4
Kube
Kube's Avatar
Coopman is correct. The service parts had two replaceable ends. Factory installed had but one. If authenticity doesn't matter to you, obtain a service part.
Just because it's 83 years old, doesn't mean necessarily that it's worn out.
Old 11-06-2019, 08:33 PM   #5
Stretch Cab
Yes it is the top one or in my case the original one. Guess going to have to spend a little cash!
Old 11-06-2019, 08:42 PM   #6
DavidG
DavidG's Avatar
Mike,
With respect, the '35 version had no replaceable ends.
Old 11-06-2019, 08:49 PM   #7
JSeery
JSeery's Avatar
Originally Posted by DavidG View Post
Mike,
So it was a fixed length?
Old 11-06-2019, 09:58 PM   #8
v8fordman
v8fordman's Avatar
David is correct and they are extremely rare.
v8fordman is offline   Reply With Quote
Old 11-06-2019, 10:00 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Mike,
Sure enough, there it is....a '35 with NO replaceable ends. Man, that DavidG knows some stuff, huh?
Thanks JM35! DD
T5 W/TORQUE TUBE
Old 11-07-2019, 08:25 AM   #10
DavidG
DavidG's Avatar
Just in case someone out there has an extra, NOS or good used, I am in dire need of one.
Thanks!
Old 11-07-2019, 08:34 AM   #11
Kube
Kube's Avatar
Mike,
I didn't know what year he was working on. The simple math leaned towards '36. Still, I didn't know '35 had zero replaceable ends.
I am trying to understand how well (or not) that worked.
Thanks for your patience with me Master. I still have much to learn from you
Sincerely Dave - thanks. You amaze me.
Old 11-07-2019, 09:17 AM   #12
DavidG
DavidG's Avatar
Don Rogers deserves the credit for that piece of wisdom and for many, many others.
One of the '35 Service Bulletins is devoted to the work-around that non-adjustable drag link. It involves a number of special fixtures and tools to bend the spindle arm to effectively shorten or length the drag link.
Overall, not exactly the brightest of ideas. But, Ford was not alone in this particular boat as I once bought a NOS non-adjustable drag link at Hershey and was happy as a clam. As V8fordman points out, they are extremely rare. Once I got back home, to my chagrin it wasn't for a '35 Ford as it was too short. I have no idea which brand X it is for, but it isn't a Ford part. Hence, I am still looking.
Old 11-07-2019, 10:14 AM   #13
JSeery
JSeery's Avatar
This is very interesting, thanks David.
Old 11-07-2019, 07:50 PM   #14
v8fordman
v8fordman's Avatar
Those side grease fitting tie rod ends (pictured) that are adjustable come in second place in terms of being rare...right behind the none adjustable tie rod. By the way, if someone finds one of the none adjustable ones for David, find another one for my '35 woodie.
Old 11-07-2019, 09:47 PM   #15
DavidG
DavidG's Avatar
Yes, the tie rod ends with side grease fittings have become scarce, which is a bit strange given that the ones with bottom fittings were only introduced in the '37 model year as a running change.
Old 11-08-2019, 10:54 AM   #16
Kube
Kube's Avatar
Good morning Dave,
I have found the correct tie rods for my beloved '39 - '40 Fords are also quite elusive. I can't imagine how scarce a proper '35 rod must be!
Of all the '39 - '40's I've judged through the years, very few have had the correct rod on them.
Mine always do Nope, no OCD going on here ...
Old 11-08-2019, 12:05 PM   #17
J Franklin
J Franklin's Avatar
Just curious, If that part was manufactured, can it not be rebuilt?
Old 11-08-2019, 01:21 PM   #18
JSeery
JSeery's Avatar
About equivalent to building from scratch. It looks like a forged part and then the ends look to be forge somehow around the ball. Don't think you could open it up to get the ball out without destroying it (the cover).
Old 11-08-2019, 06:12 PM   #19
v8fordman
v8fordman's Avatar
I have rebuilt the side grease ones before using parts from a later tie rod end. The trick is getting the stamped steel cover off without destroying it and then getting it back on. You have to make sure the spring height is the same also. Originally, the cover was rolled closed using some process. Obviously, destroying the new one doesn't matter. It has a grease fitting in the end where the parts come out.
Old 11-08-2019, 06:20 PM   #20
35fordtn
35fordtn's Avatar
As V8fordman mentioned, they CAN be rebuilt, but the 35 36 version with the side fittings and the later.. The issue is the time and effort involved.. I almost always ruined the stamped round end plate upon removal. Then peening a new one on with the proper look and ensuring it is sealed where grease wont leak out is a whole task within itself.. I've only rebuilt two and determined never ever again.
My better option for a 1935, was to build one from scratch, and even that is a all day affair..
