04-30-2021, 11:49 PM | #1 |
Clutch install
Hi All,
I am putting my resurfaced flywheel and a new clutch/pressure plate. I have a couple of questions hopefully I can get some guidance on. 1. Is there a shim required behind the flywheel when installing as it is contacting the engine slightly which when bolts are tightened jams the flywheel. 2. How many mm ( on average) do you have to pull the pressure plate down to secure to the flywheel, I have about 10mm to pull in, which would put pressure on the plate. Just wondering if this is to much? It is a new 11inch clutch plate and a new pressure plate. Cheers Corey Sent from my SM-G977B using Tapatalk |
04-30-2021, 11:59 PM | #2 |
Re: Clutch install
Might want to add car yr. Maybe inches also for us American folk. . I'm joking.
You don't need to shim it on a normal flywheel install. Maybe wrong flywheel for the engine. Linkage adjustment is usual about 1/2" play pedal to throwout. |
05-01-2021, 12:05 AM | #3 |
Re: Clutch install
Yeah good call sorry mate, Truck is a 42 ford 1 1/2 tonne truck, but has an 8BA engine in it now ( 51 ). The clutch plate when bolting to the flywheel is the distance I am meaning , before I start to bolt it down there is around ( 3/8 to 1/2 inch) to pull it down to mate with the flywheel surface ( clutch plate in between them). Just wondering if that is normally the case.
05-01-2021, 06:42 AM | #4 |
Re: Clutch install
Check that flywheel,,,,,I can’t imagine it contacting the block after being installed and tightened.
That is a great concern . Since it is a resurfaced piece it should go back like it was . I am assuming they surfaced the correct side,,,,and you put it on the correct way as well . Tommy |
05-01-2021, 07:17 AM | #5 |
Re: Clutch install
Are the flywheel bolts too long ?
05-01-2021, 07:22 AM | #6 |
Re: Clutch install
05-01-2021, 07:25 AM | #7 |
Re: Clutch install
No shim between the flywheel and crank. I do not think there are even any washers on the bolts. When installing the clutch the pressure plate will begin to snug up and the distance to the flywheel will be the thickness of the clutch plate. Gradually tighten each bolt so the pressure plate does not get distorted.
I assume you know about keeping the plate aligned with the pilot bushing using an alignment tool. Remember to remove the alignment tool after. Don't laugh, it's been forgotten before.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-01-2021, 08:26 AM | #8 |
Re: Clutch install
I've never had an issue with a flywheel hitting the block - though I've seen folks use the wrong length flywheel bolts and cause issues that way.
05-01-2021, 09:48 AM | #9 |
Re: Clutch install
As mentioned above you may have the wrong flywheel.
This picture was posted by Ross F1 in another thread. |
05-01-2021, 09:55 AM | #10 |
Re: Clutch install
Good pic there Bobc,
There is a great deal of difference in the flywheels. I think you have the answer there . Tommy |
05-01-2021, 11:57 AM | #11 |
Re: Clutch install
I think if he had the wrong flywheel, it would interfere with the block before the PP was attached. I'd say it's the PP bolts that are wrong. Also as I recall, 8BA flywheels have the PP bolt holes going all the way thru the flywheel, while 59 flywheels have blind holes.
'52 F-1, EAB flathead |
05-01-2021, 02:00 PM | #12 |
Re: Clutch install
Just had a similar incident with a 69a block.
Fitted up the flywheel and found engine which was free to turn prior to fitting flywheel would not turn. Flywheel was interfering with set screwa securing oil pump drive cover. Removed washers from screws still catching. Ended up placing a 60thou shim behind flywheel and all was clear and free turning. Phil NZ |
05-01-2021, 05:35 PM | #13 |
Re: Clutch install
Hi All,
Thankyou for all the responces, i had 2 flywheels one was on the engine and one was not. The 8BA i have was in a hot rod and is now going into my truck ,The one that was on the engine was not as heavy duty as the one on the shelf. I sent the one on the shelf to be machined ( at the time not realising there was to much difference ) and a step was machined also for the clutch plate. As in the 2 pictures one has a lip on the outside of the flywheel, this is the section that was binding on the block, i ended up getting onto the guy that machined for me ( all he does is build flathead engines) and he said silimilar. He said he finds the same issue with some engine/flywheel setups that he recieves for rebuilding, he said the easiest and quickest way is to just notch where it is binding at the spot on the outer lip a small amount (few mm) as he has had to do this on many engines over the years. I notched a few mm just where the lip was binding and this solved the problem. Thank you for all the assistance, if it's appreciated. Cheers Corey Sent from my SM-T800 using Tapatalk |
05-01-2021, 05:46 PM | #14 |
Re: Clutch install
What are you going to do about the starter engagement ??
05-03-2021, 05:27 AM | #15 |
Re: Clutch install
Hi All,
So i modified the bottom flywheel coverplate so as it would not hit the lip either, i then extended the starter motor mount by 9mm so as to sit the starter further out to allow the gear to fully engage with the flywheel. Have not tested as yet but will in the next few days. Cheers Corey Sent from my SM-T800 using Tapatalk |
05-03-2021, 04:57 PM | #16 |
Re: Clutch install
Nice work, but have you checked to see if the cover clears the oil pan?
05-03-2021, 10:49 PM | #17 |
Re: Clutch install
Yes mate fits nicely. I dummy fitted but have not fully fitted with starter etc as yet for testing. Measurements indicate it should work ok. Once I fit up I will update again.
05-04-2021, 12:43 AM | #18 |
Re: Clutch install
Geez, you really took that metric comment to heart. hahaha. Starter bendex is at least 1.5" long or 38.1mm. Maybe you could have shimmed the starter out a 1mm.
Looks good hope it works for you! Did you have to shim the flywheel then? Last edited by Tinker; 05-04-2021 at 12:54 AM. |
05-04-2021, 04:46 AM | #19 |
Re: Clutch install
Haha Tinker, i dont think 1mm would of been enough when i measured the throw and where the flywheel now sits i needed around 7mm ( i have no idea what that is in imperial! Haha no really it's 9/32! Lol).
And no i didnt shim the flywheel. So i am hoping it works out ok. Cheers Corey Sent from my SM-T800 using Tapatalk |
