05-14-2014, 09:55 PM | #1 |
Intake manifolds
Will 49 thru 53 intake manifold fit on a 48 merc engine with out modifying anything?
Thanks for any help. |
05-14-2014, 11:59 PM | #2 |
Re: Intake manifolds
Yes, may have to plug the holes for breather and oil fill in the front of the manifold... I use freeze plugs upside down- they look better that way... I used one for pcv valve...
May want to keep the fuel pump push rod for the manifold you're gonna use... Karl |
05-15-2014, 05:34 AM | #3 |
It depends on your definition of "fit"??? There will not be a distributor vacuum access point, there will be fewer attachment holes, there will be unneeded crankcase vents.
05-15-2014, 06:21 AM | #4 |
07-10-2016, 10:47 AM | #5 |
Karl do you have pictures of the plug install? Can you tell me which freeze plugs you used? I'm asking because I'll be running a late intake on an early motor
07-10-2016, 11:03 AM | #6 |
07-10-2016, 12:27 PM | #7 |
