Old 10-19-2019, 07:47 AM   #1
Ray64
Ray64's Avatar
Default Gurgling
Suddenly I hear gurgling I think is coming from carb. Just had it rebuilt. At least that's where I think it is Used a stethoscope on all of engine and all is really quiet but cant hear it with that. All was well for a couple of months after rebuild but suddenly this gurgling HELP T.I, A. RAY
Ray64 is offline   Reply With Quote
Old 10-19-2019, 08:15 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Gurgling
If it is the carburetor that is gurgling, then it seems you are experiencing the dreaded vapor lock. So, how does the engine run after it has set for a half-hour or so ?
I find that installing the fuel line so that it is completely pointing down hill, a carb to manifold spacer and/or a carb heat shield helps.
Old 10-19-2019, 08:19 AM   #3
DannL
DannL's Avatar
Whew . . . and I thought I was the only one hearing these sounds. Here's what I surmise is happening . . . once the cooling fan is off the heat from the manifold migrates to the carburetor. The gas heats and expands making the noise. After while put your finger in the carburetor intake, you may find it wet with gas. Both my Zenith 2 and the Tillitson it replaced did this.
DannL is offline   Reply With Quote
Old 10-19-2019, 08:42 AM   #4
1931 flamingo
1931 flamingo's Avatar
Where are you and how hot is it?? Is the "noise" there only with the engine off? Could be fuel in the carb bowl "boiling".
Paul in CT
Old 10-19-2019, 10:14 AM   #5
Ray64
Ray64's Avatar
im in ohio. weather is very cool. no noise after shut down. car runs perfect , idles great. its just the sound it came on after a 30 mile run sorta sounds like air in water
Old 10-19-2019, 10:58 AM   #6
1930artdeco
1930artdeco's Avatar
My car gurgled...but it was the cooling system due to a blown head gasket. Just a thought.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-19-2019, 11:03 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
Many years ago when my September 29 needed a new radiator ,
I could hear the water boiling in the radiator when I shut it off . After taking a ride .
After installing a new radiator, there is no boiling at shut down .
Old 10-19-2019, 06:39 PM   #8
Mike Peters
Mike Peters's Avatar
Our Model T gurgles after a run on a hot day, after shutdown. I figured it was continuing to thermo syphon. Normal for a T. Your A may be doing the same thing?
Mike Peters is offline   Reply With Quote
Old 10-20-2019, 09:21 AM   #9
Patrick L.
Patrick L.'s Avatar
Well, if its not vapor lock then I'd recommend checking the coolant temp.
Old 10-20-2019, 09:36 AM   #10
Purdy Swoft
If its gurgling don't take the radiator cap off or you could get scalded
