Old 11-14-2018, 05:00 PM   #1
fsacht
Default 1949 Ford Door Latches in cold weather
My '49 Ford front door latches will unlatch allowing the doors to open, but a component in the latch fails to drop down to allow the door to close and relatch. By lifting the inside handle again that tab or pawl drops down permitting the door to close and once again latch --- sometimes. I'm guessing this is not uncommon to the '49's. Mercury latch and 1950 and '51 Ford latches are different. Anyone know a fix for this, or root cause?
fsacht is offline   Reply With Quote
Old 11-14-2018, 06:48 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1949 Ford Door Latches in cold weather
What I would do is remove, inspect and lubricate.
Old 11-14-2018, 08:10 PM   #3
50fordcoupeman
50fordcoupeman's Avatar
I would call Chris at ShoeBox Central. 405-259-9222. He has helped with issues on my '50. Good luck!!
50fordcoupeman is offline   Reply With Quote
Old 11-14-2018, 11:19 PM   #4
corvette8n
corvette8n's Avatar
Whatever you do don't use Fluid Film on the latches, I put some on my Dakota tail gate latches, and my tailgate would fall open during cold weather. I finally had to wash out the Fluid film with WD40, I then used straight silicon spray.
Old 11-16-2018, 07:25 AM   #5
Frank Miller
Frank Miller's Avatar
I had one doing that and had to oil it up good. Been ok for 10 years now. I have some factory rebuilding kits for these so that is indicative of an issue.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 11-16-2018, 10:12 AM   #6
fsacht
Thank you Frank. I was beginning to think I was the only '49 owner to experience this. My father had a '49 and the right front door did it as well. I've cleaned and lubed the latches best I was able without disassembly of the latches. Factory rebuilding kits. How might I acquire a couple?
Old 11-16-2018, 01:27 PM   #7
V12Bill
V12Bill's Avatar
As I recall, that was a problem when new. One of the fifty changes for 1950.
V12Bill is offline   Reply With Quote
Old 11-16-2018, 05:21 PM   #8
Flathead
Flathead's Avatar
Yes! 49 latches are crap, only lasted one year. Clean and lube, be sure the spring is good, cross your fingers.
Flathead is offline   Reply With Quote
Old 11-16-2018, 07:13 PM   #9
bobH
The 49 that resided in my family, back in the 50's, had this problem from the beginning. Right side door in particular, would fly open at any time. There was probably a part number for that.
bobH is offline   Reply With Quote
Old 11-17-2018, 10:19 AM   #10
fsacht
Thank you all for your replies. They are all welcomed and really helpful. I'll remove the latch and see what I can see. Friday next is supposed to be up to 40 degrees so warm enough to do stuff.
Old 11-17-2018, 10:43 AM   #11
50fordcoupeman
Where do you live? Might be some one that could help.
Old 11-17-2018, 03:22 PM   #12
fsacht
Northwest Indiana north of La Porte.
Old 11-18-2018, 10:30 AM   #13
melisahe
melisahe's Avatar
my 49 tudor does the same. Havn't gotten to the fix part yet. Just started rebuild with new trunk floor, inside floor boards next.
melisahe is offline   Reply With Quote
Old 11-18-2018, 11:59 AM   #14
Habusailor
Habusailor's Avatar
Can the latches be changed over to the newer style in the 50?
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 11-18-2018, 05:47 PM   #15
wga
wga's Avatar
Ref: https://www.drislide.com/products/dr...moly-lubricant
Used this product on my 49 wagon. Cleaned all the schmutz that had accumulated over the past half century or so. This product does an excellent job on lubrication, plus it dries - not sticky as so many other lubricants. Used on the door hinges as well. Doors open and close easier, no door slamming required.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 11-18-2018, 06:00 PM   #16
leon bee
I'd also like to know this.
leon bee is offline   Reply With Quote
Old 11-19-2018, 08:04 AM   #17
Frank Miller
Not without changing the door and whatever might be involved in fitting the latching mechanism to the the jamb.
Thread Tools
Display Modes
