Old 11-09-2019, 09:58 AM   #1
zoegrant
zoegrant's Avatar
Default Two barrel card spacer with pcv
Does any company make a two barrel carb spacer with a PCV port ??
zoegrant is offline   Reply With Quote
Old 11-09-2019, 10:23 AM   #2
Anteek29
Anteek29's Avatar
Default Re: Two barrel card spacer with pcv
If not, should be easy to make?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 11-09-2019, 10:58 AM   #3
KULTULZ
KULTULZ's Avatar
Question Re: Two barrel card spacer with pcv
What year and carb style? You are upgrading?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-09-2019, 04:00 PM   #4
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
if you're using a 2100 Ford 2 bbl, just about any mid to late '60s 302 or 351W has what you want
streetdreams is offline   Reply With Quote
Old 11-09-2019, 05:27 PM   #5
5851a
If you go past 1972 generally you will find it will have a egr valve attached.
5851a is offline   Reply With Quote
Old 11-09-2019, 09:29 PM   #6
paul2748
paul2748's Avatar
I have seen them advertised, but don't remember the vendor.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-10-2019, 02:23 PM   #7
Hot Rod Reverend
Hot Rod Reverend's Avatar
Check speedway automotive for the Stromberg style 2 barrels (3 bolt mounting bases) - they should have different heights. Also... and I hate to say it, ebay.
https://www.ebay.com/itm/For-Strombe...AAAOxydB1Si8re
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 11-11-2019, 11:32 AM   #8
poolplayer1
Go to Ebay and in the search bar, type in C4AE-9A589-D and take a look at that spacer.Might be what you are looking for.
poolplayer1 is offline   Reply With Quote
Old 11-11-2019, 02:14 PM   #9
zoegrant
zoegrant's Avatar
I need a 3 bolt mounting base not the 4 bolt...please let me know is someone runs across a supplier...thanks
Old 11-11-2019, 05:05 PM   #10
40cpe
40cpe's Avatar
Here you go:
https://www.jalopyjournal.com/forum/...carbs.1172600/
Old 11-11-2019, 06:14 PM   #11
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Two barrel card spacer with pcv
Perfect.
Too bad the vendor wasn't listed. Should also consider a phenolic spacer between the carb spacer and carb body.
File Type: jpg Carb Spacer - Phenolic w Gaskets - H94-S97.jpg (52.8 KB, 5 views)
- WHY IS IT ... -
Old 11-11-2019, 06:15 PM   #12
zoegrant
zoegrant's Avatar
40cpe... the spacer on the left, does that have a port for a pcv hose ?
How large an opening is needed for a pcv hose. Looks like a small diameter...thanks for finding this for me. Who is the vendor ?
Old 11-11-2019, 08:29 PM   #13
paul2748
paul2748's Avatar
The seller looks to be a HAMB member (2900 plus posts). It looks like you will have to get a screw in nipple to attach a hose. Contact the seller for info if you are a HAMB member
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 11-11-2019, 08:57 PM   #14
40cpe
40cpe's Avatar
Click on the HAMB link. You will have to ask those questions to the seller.
Old 11-12-2019, 07:33 AM   #15
Neal
Neal's Avatar
Don't the gas heaters (southwinds) have what you are looking for? I do not know if the port is the correct size.
The picture above looks like one.
Neal is offline   Reply With Quote
