05-30-2010, 02:36 PM | #1 |
Routing of oil gauge tubing
Got an oil gauge from Sullivan's Garage and picked up some copper tubing to run instead of the plastic stuff. How do you route the tube? Under the carb & manifold and back up the firewall? Anyone have a picture of theirs they would share?
05-30-2010, 05:38 PM | #2 |
Re: Routing of oil gauge tubing
This was on an early 29 Roadster. Had a victory gauge. Not pretty but it worked?
05-30-2010, 07:25 PM | #3 |
05-30-2010, 09:39 PM | #4 |
Kevin, Don't use copper tubing for your oil pressue gage line. The vibrations from a Model A will cause the copper to work harden and snap off. You won't know it happened (unless the oil gets hot enough to burn on the tailpipe) until you stop and find oil running from the bottom of your car. Trust me, I tried copper and luckily stopped before it pumped less than a quart out.
05-30-2010, 10:13 PM | #5 |
Tom, the bottle on the firewall was an intake oiler. The inside of the head had more carbon than you can imagine. Don't think anyone had ever checked how much oil was being sucked into the motor. Very little wear on the standard bore. The oil line to the gauge is just below the carb. Had a snubber attached to keep that high oil pressure from attacking the gauge. Both pluming lines, oiler and oil pressure were copper. Ditto on the gas line to the carb. The line under the dash was an original three piece. Two ferrules and one piece of steel tubing sweated together
05-30-2010, 10:25 PM | #6 |
