09-03-2018, 02:18 PM | #1 |
Headlight Switch Issue
Looking for ideas on a lighting problem with my '30 Std Roadster. I recently rebuilt the steering gear and replaced the light switch while at it. Now, regardless of where I put the lever on the steering wheel (in the parking, low or high beam position), all three filaments come on on both headlights. I suspect the issue must be with the switch. Any similar experiences out there? Thanks!
09-04-2018, 12:06 AM | #2 | |
Re: Headlight Switch Issue
The reason I ask is that the plug ends of the harness that connect to the headlight bucket socket could be all touching each other on one or both connections. Those repop harness ends can be tricky and so can the repop headlight bucket sockets. |
09-04-2018, 05:39 AM | #3 |
Yes, it did include the new harness. We’re on the same wavelength. Today’s plan is to check the headlight connections as you suggest. Yesterday I took the switch apart to check it and couldn’t find anything out of order. Thanks for the input!
Sent from my iPhone using Tapatalk |
09-04-2018, 03:54 PM | #4 |
