02-19-2019, 08:09 PM | #1 |
Posies 2040 Front Spring 1937 Ford??
Is the Posies 2040 spring the correct spring for a 1937 ford. Looking to drop the front end and want to install a reverse eye spring.
02-19-2019, 09:32 PM | #2 |
Re: Posies 2040 Front Spring 1937 Ford??
That's the one we used for a '40 (same as '37). Free shipping from Speedway.
02-20-2019, 08:54 AM | #3 |
Rusty, Here's a 40 Ford that has the original stock suspension EXCEPT for the Posie 2040 reversed eye spring. See the first photo in posting #3.
You can see the tiny rake. It lowers the front end 1 in. https://www.fordbarn.com/forum/showt...hlight=rake+40 Last edited by 19Fordy; 02-20-2019 at 09:03 AM. |
02-20-2019, 10:27 AM | #4 |
Depending on the amount of rake you are looking for, it may take more than a spring. A dropped axle can drop it a couple of inches.
02-20-2019, 10:27 AM | #5 |
The alterative is to just buy the reversed eye main leaf and build your own spring from the original leaves. Leave out the top two short leaves and it should give you the stance you are looking for on your 37.
02-20-2019, 10:47 AM | #6 |
02-20-2019, 03:37 PM | #7 |
As per drolston, like this.
02-20-2019, 07:23 PM | #8 |
I think the springs on my car are worn out. I have never done a front spring swap. What’s the easiest way to do it. Sounds like dropping the front axle and spring is the best option. Then use a spreader to remove the spring??
02-20-2019, 08:23 PM | #9 |
Spreader is required for your year.
02-20-2019, 11:07 PM | #10 |
You don't need to remove the axle in order to remove and install a new front spring.
Raise and support the front of the car with jack stands. On a 40 ford I used a spring spreader to relive the pressure on the shackles. Un bolt the spring from both shackles. Then remove the center u bolt and carefully lower spring to the ground. ( I don't think i skipped any steps.) Take plenty of photos. |
02-21-2019, 05:57 AM | #11 |
I used both frt and rear reverse eye Posie on mine
02-21-2019, 09:11 AM | #12 |
Rusty: Be sure and read all the info., (including any links) in this Fordbarn thread about installing a Posie reversed eye spring.
https://www.fordbarn.com/forum/showt...e+front+spring This thread shows how to install a reversed eye spring using a spring spreader. much easier than my method above. https://www.fordbarn.com/forum/showthread.php?t=146018 Lots more good info. here. https://www.google.com/search?q=inst...hrome&ie=UTF-8 Last edited by 19Fordy; 02-21-2019 at 12:25 PM. |
02-21-2019, 02:13 PM | #13 |
You could also try a U bolt clamp
02-22-2019, 05:17 AM | #14 |
I bought a Posies reversed eye spring for a Forty coupe, it was too soft and flattened out almost straight. Took it off and fitted a reversed eye main leaf to the original spring pack minus two leaves, worked great.Ive learnt over the years that FoMoCo parts are the best wherever possible.
