01-27-2015, 10:48 AM | #1 |
cap universal inner housing to tourque tube
is this directional or can it go on in any direction. mine has to holes
in the cup one on each side?? do not remember how it came off fredski |
01-27-2015, 11:20 AM | #2 |
Re: cap universal inner housing to tourque tube
@ the 3 and 9,......for the clocking..
01-27-2015, 11:41 AM | #3 |
01-27-2015, 12:01 PM | #4 |
The two holes in the inner cup should be placed horizontal, so they are at 3 and 9 o'clock.
01-27-2015, 12:01 PM | #5 |
Ford made two different versions of the universal housing/clamshells/sphere joint. One version has the 6 bolts "staggered" around the perimeter of the housing. These go together only one (well, maybe 2) way. When assembled the holes in the sphere are at the 3 and 9 o'clock position. (i.e horizontal centerline) The other version has the 6 bolts "evenly spaced" around the perimeter of the housing. These go together in any of 6 positions - but assembled originally with the clamshell splits at the horizontal centerline. And like the unequal version, the sphere is assembled with the holes at the 3 and 9 position. Service Bulletins describes the changes. And a caution not to mix up parts (although given the change this might be hard to do.) Hope this helps. Edit: Tom beat me by less than a minute. Joe K.
Shudda kept the horse. |
01-27-2015, 12:02 PM | #6 |
this here on the Barn. The 2 holes, one on each side,..would be at the 3 o'clock and 9 o'clock position, as if you are viewing a clock....okay? |
01-27-2015, 12:24 PM | #7 |
okay thank you all . I now understand the right way to install
fred g |
