Old 08-12-2018, 11:06 PM   #1
fordor41
fordor41's Avatar
Default 1960 ford rear shackles
I have a 1960 ford fairlane 500 coupe that was lowered before I got it It has 4" lowering blocks in the rear and the shackles are hanging down. It looks like the shackles should be up with the spring eye just below the frame. anyone know for sure how they should be orientated?
fordor41 is offline   Reply With Quote
Old 08-13-2018, 02:44 AM   #2
KULTULZ
KULTULZ's Avatar
Default Re: 1960 ford rear shackles
It would be easier to visualize if you provided a photo. It's hard to say what was done.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 08-13-2018, 01:14 PM   #3
dmsfrr
dmsfrr's Avatar
What I'm picturing in my mind looks pretty scary.
Flipping the shackles and using 4in lowering blocks are not the best ideas, and they'd likely cancel each other out for ride height change. ???
Old 08-13-2018, 03:43 PM   #4
KULTULZ
KULTULZ's Avatar
Red face Re: 1960 ford rear shackles
Yeah, me too. I thought I was going to see these-
But I now realize he meant the shackles had been reversed. Very bad for the main leaf but was common practice in the day to temporarily restore ride height with a weak, sagging spring (or a cheap and easy way to jack one up ... ).
File Type: jpg Suspension- RR 1957-59 FORD _2 - Spring Shackle.jpg (52.3 KB, 57 views)
- WHY IS IT ... -
Old 08-14-2018, 09:33 AM   #5
56sedandelivery
56sedandelivery's Avatar
come on fess up. You didn't use those back in the day.
56sedandelivery is offline   Reply With Quote
Old 08-14-2018, 11:22 AM   #6
dmsfrr
dmsfrr's Avatar
1971 Mercury Comet, G50 x 14 rear tires and air shocks
Old 08-14-2018, 12:20 PM   #7
KULTULZ
KULTULZ's Avatar
... alas ...
My brother had a '57 that he decided to raise with 2 X 4's one day. Took it on the street for a burnout and the blocks came flying out.
No use being one if you can't act like one...
- WHY IS IT ... -
Old 08-14-2018, 06:41 PM   #8
56sedandelivery
I have one better. Back in the days when the gasser were hot I did my 57 over to look like one. Straight axle up from then took the front springs and put them in the back to level it out. While it looked cool it rode like a tank. I did weld the springs in the back to the axle and frame so never had them come flying out.
Old 08-14-2018, 10:21 PM   #9
fordor41
fordor41's Avatar
That's how I assumed the springs should be. Shackle up
Old 08-14-2018, 10:30 PM   #10
fordor41
fordor41's Avatar
I found a pic of the car that I bought from a few(?) yrs ago. It was a correct ride height. By the time I got it, it had been lowered 4" F & R. I assume someone played with the rear springs and assembled them wrong and the 4" lowering blocks was their way to correct it. Surprisingly it handles and drives great. Only problem is the frame is so low I can't get a jack under it! It appears they heated the front coils to lower the front
