02-02-2018, 06:52 PM | #21 |
Re: Flaathead Ted brake kit install
I'm all ears! Waiting to hear about this possibility.
02-03-2018, 11:11 AM | #22 |
Ditto here!
02-03-2018, 12:42 PM | #23 |
Absolutely go for it. I'd love to be the USA road test for a set. The Lincoln setup is just too expensive for a lot of us. My 40 would be my test case. I've been wanting to do something with the brakes for years. Come on Ted, you can do it!
02-03-2018, 01:45 PM | #24 |
Ted>>>I will see what I can do between doing steering boxes>>>
Thanks Ted!!! But how about doing steering boxes between doing Lockheed floaters instead? 8^) Jack E/NJ |
02-12-2018, 11:54 AM | #25 |
Ted,
I have your kit installed and saw a little improvement, but nothing like you show in your videos. I noticed you mentioned that the shoe material needs to be soft. Does that mean the woven fabric material? Thanks, Brad
Brad Williamson |
02-12-2018, 12:20 PM | #26 |
02-12-2018, 01:36 PM | #27 |
Jerry,
What type of material is on your brake shoes? Brad
Brad Williamson |
02-13-2018, 03:02 PM | #28 |
Here's some lining # NA3923 woven .NA3812 grey soft bonded,not sure if theses numbers would mean much to you ,Ted
02-13-2018, 03:48 PM | #29 |
I would be interested in a set for juice brakes as well.
02-13-2018, 07:46 PM | #30 |
I'm very interested in a set for hydraulics
02-14-2018, 02:57 PM | #31 |
If anyone is confused about types of linnig to use try the Model A site on FB ,or search ,whats good for a A is good for a v8 ,Ted
02-15-2018, 02:02 PM | #32 |
Very cool & informative string.
Nomad |
02-15-2018, 09:30 PM | #33 | |
Ted it would seem that there is a lot of interest. For you to return to this project could make a lot of guys happy and safer stopping. I include myself with the people who would like you to take up the task. Phil NZ |
02-15-2018, 09:43 PM | #34 |
Ted, why are the brake linings we should use with the mechanical energizer kit such a mystery. Can you give us the correct mfg. and their part # & where to get? Your direction to the FB Model A site and the search "whats good for a A is good for a v8" didn't find anything?
Thx
Nomad |
02-16-2018, 05:09 PM | #35 |
https://www.jalopyjournal.com/forum/...ersion.387348/
Check this out there is a heap of info on the Hamb on how to convert early Ford brakes to bendix operation |
02-16-2018, 06:43 PM | #36 |
02-16-2018, 10:13 PM | #37 | |
02-16-2018, 10:17 PM | #38 |
02-17-2018, 08:23 PM | #39 |
I looked at the Ham and that's quite a involved fit up I am hoping to do something simpler than that Lincoln set up ,I will put these through the dealers if successful ,this may need to be in the winter for testing ,
Brake linings The lining numbers I have given are good to use but I don't know if these are USA numbers , I will look into it and report back .What's good for a Model A is good for a v8 ,any search on brakes on the A site will give some useful info. Ted |
02-20-2018, 03:10 PM | #40 |
Here's a picture of the linings previously mentioned ,These can be riveted or bonded ,Ted
