02-26-2019, 02:55 PM | #1 |
boat motor
they say its industrial, i say boat. note the carb angle, manifolds, and gearbox https://rmn.craigslist.org/pts/d/red...824609559.html
02-26-2019, 03:14 PM | #2 |
Re: boat motor
Ford industrial engine that someone converted for use on a boat.
02-26-2019, 04:18 PM | #3 |
Re: boat motor
with water cooled exhaust manifolds it was used on a boat
02-26-2019, 11:40 PM | #4 |
Re: boat motor
Never cared for the look of an engine being touted as good; sitting there with the spark plug holes open.
02-27-2019, 07:30 AM | #5 |
Re: boat motor
Saw a flattie in an old wood speed boat in the 60s just like it. Read about an industrial v8 used as a pump and it had the same type of manifolds & cooling system no radiator needed. Cool huh !
02-27-2019, 10:32 AM | #6 |
Re: boat motor
Wedge-shaped carb adapter plates can be used with inboard boat engines mounted mid-ship of the boat to correct for the function of the carb float and reduce potential carb leakage. An option I have used is what is called a "down-angle" drive unit which is simply a universal joint coupling enclosed by a housing located between the transmission and the propeller shaft connecting flange. This unit lowers the elevation of the engine inside the boat to better accommodate an engine enclosure box/deck and to correct the engine's angle to allow proper carb float function. Both methods typically improve the circulation of coolant thru the engine block. Last edited by Drbrown; 02-27-2019 at 10:48 AM. |
02-27-2019, 02:28 PM | #7 |
Re: boat motor
There was a lot of gear heads that got into boat racing back in the day. The Ford V8 was used in some pretty well built boats as well as race boats.
02-27-2019, 03:41 PM | #8 |
Re: boat motor
Had a home built 18 footer many years ago equipped with a converted 59AB.
Biggest problem was the water pumps that had rubber impellers that would get chewed up by debris sucked up from the river. Spent time while drifting to replace the failed impeller with one of the spares that was always carried, that is until someone made metal ones to replace the rubber ones.
