Old 01-13-2020, 10:35 PM   #1
dmaxweb
dmaxweb's Avatar
Default Body Bolts
I came across several that were not tight and somewhat rusty so I'm going to replace them all. Other than cosmetic, is there any reason to use body bolts from suppliers vs. locally available grade 8 fine thread?
dmaxweb is offline   Reply With Quote
Old 01-13-2020, 11:31 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Body Bolts
IMO, Grade 8, fine thread bolts would be overkill. They only hold wood after all - not steel to steel. I use bolts from the local hardware store and still, i'm sure the wood would give first.
Old 01-13-2020, 11:43 PM   #3
Mike Peters
Mike Peters's Avatar
If you mean the bolts that attach the body to the frame, hardware store bolts will be fine. They are all 3/8" or 7/16". Plenty heavy, as Synchro says.
Mike Peters is offline   Reply With Quote
Old 01-14-2020, 03:07 AM   #4
Pete
Pete's Avatar
But what about the old wive's tale of the body coming off in a wreck and leaving you in one ditch and the chassis in the other ditch??
Heaven forbid if you have seat belts that are attached to the frame...
Old 01-14-2020, 06:41 AM   #5
Synchro909
Synchro909's Avatar
Yeh, I roll about laughing when I hear that one!
