Old 12-07-2019, 04:05 PM   #1
Terranova
Default '36 fordor sedan rearend.
Are they normally 6 spline or 10 spline? Is there any way of telling without taking it apart?
Thank you.
Mike T
Terranova is offline   Reply With Quote
Old 12-07-2019, 08:13 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: '36 fordor sedan rearend.
'36 is normally going to be 10-spline. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-08-2019, 12:48 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
One indicator that I use is to look for a zerk grease fitting in the center, bottom area of the torque tube. If the zero is there, then most likely there is a center bearing in torque tube, with a solid driveshaft, which usually has six splines, and a 6 to 10, or 6 to 6 spline coupler connecting the driveshaft to the pinion gear. Usually, if there is no provision for a zero fitting in center of torque tube, there would be hollow driveshaft, with a 10 spline bung welded in place.
John
