Old 12-06-2019, 10:54 AM   #1
Mr. Will
Mr. Will's Avatar
Default 1933-1936 Rear End Widths
Can anyone tell me what the overall width is, bolt flange to bolt flange, on 33-34 and also 35-36 rear banjo rear ends? Any input would be appreciated.
Thanks Dan
Mr. Will is offline   Reply With Quote
Old 12-06-2019, 02:24 PM   #2
Mr. Will
Mr. Will's Avatar
Default Re: 1933-1936 Rear End Widths
I found it.
1928-1931 57.0″ Spring Mount Eye to Eye 49.5″
1932-1934 57.75″ --------------------------- 47.5″
1935-1936 59.5″ ----------------------------48.25″
1937-1941 59.5″ -----------------------------48.5″
1942-1948 61.0″
Old 12-06-2019, 06:53 PM   #3
JSeery
JSeery's Avatar
Some information here.
Old 12-07-2019, 12:13 AM   #4
cas3
thats a good article posted by jseery, every jalopy builder should have it bookmarked. mr will you havnt given us a clue what you are building yet, but on my 34 coupe i went for the 35 to 41 housing width. several reasons, its a little stronger, parts are more common, the 3/4" per side wider works out well with my 750x16's on the rear. my car is a kids jalopy from the 50's, not a restoration. a work in progress i think they call it! happy motoring, skip
Old 12-07-2019, 12:27 AM   #5
Mr. Will
Mr. Will's Avatar
Thanks for the article, will save it in my database.
Old 12-07-2019, 12:38 AM   #6
Mr. Will
Mr. Will's Avatar
I have a 33 coupe and also have a 36 banjo I want to use. I was concerned with the width of the later rear and fender clearance should I decided to run fenders.
I know I can make up the difference with wheel offset just wanted to verify before i ventured there.
Your coupe looks great.
Thanks Dan
