Old 12-05-2019, 08:02 PM   #1
30-9
Default Gas and ways to seal
Hi gents
Iím having difficulty sealing the fuel connection into carb. I know Teflon tape is no good. Can I use seal all? Or what do you recommend?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 12-05-2019, 08:07 PM   #2
Kube
Kube's Avatar
Default Re: Gas and ways to seal
How about GOOD threads? It may require a different carburetor cover (top plate). They are plentiful and cheap.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 12-05-2019, 09:01 PM   #3
40cpe
40cpe's Avatar
Threads don't seal it. Depending on the application, the flare or ferrule does the sealing. The threads provide pressure for the seal.
40cpe is offline   Reply With Quote
Old 12-05-2019, 10:24 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
I have tinned the sealing part with solder
Old 12-05-2019, 10:51 PM   #5
tubman
tubman's Avatar
Assuming you are referring to a 94 type carb, have you tried replacing the ferrule? They sometimes get damaged. Very rarely, the entire line needs to be replaced.
tubman is online now   Reply With Quote
Thread Tools
Display Modes
