Old 11-30-2019, 08:16 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 8ba Heads 7RT to EAB.
So just cross checked clearances prior to getting EAB Heads milled.
The gasket I used to check was a Felpro with 50 thou at fire ring.
My new Felpro 7525 measure 68 thou at fire ring.
So figure to allow 50 thou on the new gaskets for calculation purposes.
Tighest clearances are at 4 and 8 pistons 95 and 98 respectively. These were at centre area of piston. Used 4 balls in total at each piston.
For the recommended 40 to 50 clearance that gives 50 to 55 as a good range.
Torque up at 3 cycles to 60 to 65 ft/lbs.
Think I'm on right track. Yes?
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 11-30-2019, 10:16 PM   #2
JSeery
JSeery's Avatar
Default Re: 8ba Heads 7RT to EAB.
Little heavy on the head torque values. The original spec's are in that range, but more than required and the blocks are fairly thin.
Old 11-30-2019, 10:31 PM   #3
Ol' Ron
Ol' Ron's Avatar
Absolutely not. First the 45 thou piston to head clearance is at the closest part of the head, the top is not important. Second, max head bolt/nut is 45 for three hest cycles.
Old 11-30-2019, 11:06 PM   #4
Phil Gillespie
Appreciate your input and will follow. Just measured the bore, 1st time Ive had the heads off. Was told it was 3 3/16 plus 40 thou over.
It is infact 125 thou over at 3.200 measurement. Heads to be dropped off tomorrow with a" promised" 2 day turn around. Have had the EAB heads for a couple of years so nows the time to exchange.
The head torque got off Van Pelt site but will be guided by 45 ft/lbs.
Phil NZ
Old 12-01-2019, 01:15 PM   #5
cadillac512
Phil NZ
Hi Phil. Stock bore of 3.188 plus .020" would be 3.208" . Could that be what your seeing? .125 over would be 3.313" . Please let us know how the EAB heads perform!
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
cadillac512 is offline   Reply With Quote
Old 12-01-2019, 05:11 PM   #6
Phil Gillespie
Yep my measuring was out. Thanks for that.
Will advise when all is up and running again.
Phil NZ
Thread Tools
Display Modes
