Old 12-03-2019, 09:31 AM   #1
74bowtie
74bowtie's Avatar
Default Bought a speedometer not sure if it Ford
I picked this up at an antique shop, I thought is was for a 1935-36 Ford. The face looks correct but no Ford script on the face. The brackets on the back side are a lot different also. Does anyone know what this may be from?
74bowtie is offline   Reply With Quote
Old 12-03-2019, 09:44 AM   #2
Ron Pilger
Ron Pilger's Avatar
Default Re: Bought a speedometer not sure if it Ford
35/36 Ford, i believe
Ron Pilger is offline   Reply With Quote
Old 12-03-2019, 10:06 AM   #3
Don Rogers
Don Rogers's Avatar
1935 Ford face. But the back of the speedo seems different than standard.
Don Rogers is offline   Reply With Quote
Old 12-03-2019, 12:38 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
.'cuz it's a Deluxe speedo...FOUR digits on the trip meter instead of three. DD
T5 W/TORQUE TUBE
Understand the subject at hand before you disagree!
Old 12-03-2019, 01:02 PM   #5
Don Rogers
Don Rogers's Avatar
Bad choice of words on my part...Should have said "different than usual" "instead of different than standard"
Getting back to my original post....the back of this speedo seems strange and not the usual back as shown below.
Old 12-03-2019, 03:07 PM   #6
74bowtie
74bowtie's Avatar
The back is what is throwing my off, did Ford use the same style mounting on all the body style open car and closed
Old 12-03-2019, 05:04 PM   #7
Don Rogers
Don Rogers's Avatar
Yes, The same basic speedometer mounting was used for all body styles. Since Ford didn't make the speedos (made by Waltham, Delco and Borg Warner) its possible that this speedometer was made for someone besides Ford.
Old 12-03-2019, 05:20 PM   #8
Viv W
The speedo face and needle definitely look to be 1935 Ford, but the back is not right and even the trip mileage reset is in the wrong place.
I would think the actual speedometer internal parts are not Ford, but some other make, and someone has liked the ford speedo face and fitted it to this guage.
Viv W is offline   Reply With Quote
Old 12-03-2019, 06:00 PM   #9
TJ
TJ's Avatar
Is there a manufacturer name anywhere on the speedo?
Old 12-03-2019, 06:51 PM   #10
74bowtie
74bowtie's Avatar
Yes it has Delco Appliance Corp, here is a picture also.
GM owns Delco and has since 1929
Old 12-03-2019, 09:25 PM   #11
DavidG
DavidG's Avatar
Don,
Wouldn't that be Stewart Warner?
Old 12-03-2019, 09:35 PM   #12
40cpe
40cpe's Avatar
Doesn't a ford speedo have the cable connection threads on the OUTSIDE?
Old 12-03-2019, 09:55 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
Well, here's Capt Kirk's speedo out of his '35 Cabriolet. Cable threads are on the INSIDE, and the face looks identical in layout, graphics and clocking of numbers. Even the needle looks the same. The trip re-set IS in a different location. DD
https://www.fordbarn.com/forum/showt...35+speedometer
T5 W/TORQUE TUBE
Old 12-03-2019, 10:30 PM   #14
40cpe
40cpe's Avatar
I guess my memory isn't so good
Old 12-03-2019, 11:20 PM   #15
Don Rogers
Don Rogers's Avatar
Dave, Yes it is Stewart Warner, not Borg Warner.
Old 12-04-2019, 03:37 PM   #16
74bowtie
74bowtie's Avatar
Thanks for the help everyone, I will keep searching and I will find what it fits...I hope.
