Old 11-20-2019, 07:04 AM   #1
jharrellh
jharrellh's Avatar
Default Remove/Replace Headlight Reflector
I am probably overlooking the obvious, but I didn't want to force anything - how do you remove the headlight reflectors from the headlight bucket?
jharrellh is offline   Reply With Quote
Old 11-20-2019, 07:33 AM   #2
dbaldwi3
dbaldwi3's Avatar
Default Re: Remove/Replace Headlight Reflector
Open lens cover, remove bulbs, gently pull reflector bucket forwards it will slide right out.
dbaldwi3 is offline   Reply With Quote
Old 11-20-2019, 08:30 AM   #3
jharrellh
jharrellh's Avatar
Thanks for the fast reply, I will give it a shot!
Old 11-20-2019, 09:28 AM   #4
Ray in La Mesa
A little closer look will reveal that at the 3 & 9 o'clock positions are small tabs at the front edge of the bucket that hold the reflector in, The reflector should just slide off the bulb socket (the socket is notched to index the bulb filaments).
Ray in La Mesa is offline   Reply With Quote
Old 11-20-2019, 09:39 AM   #5
Joe K
Joe K's Avatar
If your socket is corroded to the reflector, you can undo and remove the "focus screw" at the back of the bucket. This will at least allow you to access the back side of the bucket, potentially snip the wires for removal, or demounting the "plug" remove the entire assembly with the bulb socket in place.
A lot of "weathered" buckets have the 3 & 9 tits corroded off - and a corresponding ring of rust making a "rust joint" between the reflector cork gasket and the bucket. A utility knife can knife this and free the reflector.
If you're to this point you probably want to get new reflectors anyway with new gaskets.
Joe K
Shudda kept the horse.
Old 11-20-2019, 10:56 AM   #6
jharrellh
jharrellh's Avatar
Thanks again everyone! The lighting is pretty bad where I have the car stored, looking closer this morning I could see the tabs at 3 and 9 that I had to unbend. Now I just need to deal with a stripped adjusting screw. Any suggested vendors for quality sockets?
Old 11-20-2019, 11:26 AM   #7
redmodelt
redmodelt's Avatar
I just push the reflector to one side to release from the tab if needed or just pop it out. The tabs are there to keep it from rotating. The original reflector had the socket offset by just a little and the tabs keep it centered. You should not need to bend them up.
Old 11-20-2019, 12:14 PM   #8
jharrellh
jharrellh's Avatar
Thanks, someone had bent these over pretty aggressively in the past but I'm all set now.
Old 11-20-2019, 01:20 PM   #9
Charlie Stephens
You didn't ask but I thought I would mention that the best reflectors are available from Bratton's. They invested to have the correct tooling made. I don't know is they have released their product to other Model A suppliers.
Charlie Stephens
Old 11-20-2019, 01:40 PM   #10
ryanheacox
ryanheacox's Avatar
I don't think any vendor has a high quality headlight socket. They can be fiddled with and made pretty decent but if you want good ones maybe call Bert's in Denver and see if they have any originals.
Old 11-20-2019, 10:03 PM   #11
Gary WA
Gary WA's Avatar
dont forget gasket cork
www.whidbeymodelaclub.com
Old 11-20-2019, 11:02 PM   #12
mhsprecher
mhsprecher's Avatar
I bought Bratton's reflectors for both my Model As. What a difference.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
mhsprecher is offline   Reply With Quote
