Old 11-12-2019, 10:15 AM   #1
tommyleea
Default 55 F100 Centerlink
Does the original centerlink (connecting rod tube), that the tie rod ends screw into have any bends in it, or is it completely straight? Also, is the tube hollow all the way thru, or just at the ends where the tie rod ends screw into it? Thanks..
tommyleea is offline   Reply With Quote
Old 11-12-2019, 04:50 PM   #2
flathead 53
Default Re: 55 F100 Centerlink
no bends in it , pretty sure hollow
flathead 53 is offline   Reply With Quote
Old 11-12-2019, 04:52 PM   #3
flathead 53
I replaced mine on my 53 with a heavy duty one from mid fifty , I have the original one out in the garage ,I can check it out if you want.
Old 11-12-2019, 07:31 PM   #4
tommyleea
Thanks..I finally was able to remove both tie rod ends. The tube is hollow. I have replaced many tie rod ends, but really never thought about the tube being hollow or not..Funny how that works. My tube has a slight bend to it, but not dented in like I thought it would be if hollow.
Thread Tools
Display Modes
