Old 11-03-2019, 06:54 PM   #1
NZ28ModelA
NZ28ModelA's Avatar
Default Headlight bar rubber gaskets
Hi Fellow Model A Drivers,
i have just replaced the rubber gaskets beneath my headlight bars because they were stretched out and looked horrible.
Unfortunately when i tightened the nuts up after fitting the new ones, they are just as stretched out as the old ones!
I guess i have over tightened them, but i presumed a structural bracket like that would have to be pretty tight??
Kindest regards
Steve
NZ28ModelA is offline   Reply With Quote
Old 11-03-2019, 07:08 PM   #2
Bob C
Default Re: Headlight bar rubber gaskets
They did not originally have the rubber pads.
Bob
Old 11-03-2019, 07:19 PM   #3
kenparker
kenparker's Avatar
I recently saw and listing for two types of rubber pads. One style had the extended ridge that surroounde the light bar "pad" The second style rubber pad was "hidden'. I think it was Berts catalog. kp
kenparker is offline   Reply With Quote
Old 11-03-2019, 07:31 PM   #4
Gary WA
Gary WA's Avatar
No rubber! Helps with grounding!
www.whidbeymodelaclub.com
Old 11-03-2019, 10:06 PM   #5
redmodelt
redmodelt's Avatar
Grounding will still be thru the bolt and lock washer. You can't ground thru two painted surfaces, fender and light bar even if there was no paint on the light bar.
Old 11-03-2019, 11:48 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
I like the ones with the bead around the outer edge.
I have found that there are a couple of different 'sizes' made and sold by the vendors. I had to buy a couple of different ones to find a set that fit my light bar. I got them from Bert's (Part #A13123BL). This is for a 30/31. I believe the 28/29 are different?
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
https://www.youtube.com/watch?v=aH2TvmjxIFM
Old 11-04-2019, 08:17 AM   #7
Tinbasher
Tinbasher's Avatar
The key to what your doing is the fit of the fender brkt. the fender and the headlight bar. If everything is nice and flush it won't push the gasket out.
Tinbasher is offline   Reply With Quote
Old 11-04-2019, 02:58 PM   #8
Mad Mac
I cut out the required shape from an old discarded pair of Kiwi (Red Band) gumboots and it worked really well. The fabric backing prevents distortion.
Mad Mac is offline   Reply With Quote
Old 11-04-2019, 06:16 PM   #9
jw hash
jw hash's Avatar
i stop using the rubber on the head light bar years ago. they were not there originally so why would you install them. they all look tacky after time.
jw hash is offline   Reply With Quote
Old 11-07-2019, 03:53 AM   #10
NZ28ModelA
NZ28ModelA's Avatar
What part of the country are you from Mad Mac??
Old 11-07-2019, 12:24 PM   #11
captndan
captndan's Avatar
Berts spells it out which to use.
captndan is offline   Reply With Quote
Old 11-07-2019, 03:05 PM   #12
Mad Mac
Waikato
