Old 08-15-2018, 05:44 PM   #1
kimeccles
kimeccles's Avatar
Default 1930 Cabriolet window slide bar
Folding windshield slide bar, not window.
Can someone please tell me where the metal spring part goes? What is the right order, I just do not see this in my books. I think one end closest to the inside is just the metal washer with rubber insert and the big knurled knob on top of the slide direct to the door jamb.
If that is OK then I need to know how to install the other end. It may be spring then metal slide then special little bolt that screws into the 12x24 end of the pin on the windshield.
Of course I may be wrong on both. LOL.
Thanks
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 08-15-2018, 08:44 PM   #2
figment
Default Re: 1930 Cabriolet window slide bar
I think you meant to type windshield slide bar .
figment is offline   Reply With Quote
Old 08-15-2018, 09:45 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Parts catalogs may have an exploded view, showing the correct order of the parts.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-15-2018, 09:47 PM   #4
kimeccles
kimeccles's Avatar
Yes, I just need to know how it is supposed to be attached. I did not see in standards or Les book I had so far.
thanks
Old 08-16-2018, 06:16 PM   #5
ronn
no spring?
Old 08-17-2018, 08:50 AM   #6
Jwilli
Jwilli's Avatar
Picture of my 1930 68B swing arm. Mine does not have a spring anywhere. If you can post a picture of your items maybe someone will know the correct answer.
Jwilli is offline   Reply With Quote
Old 08-17-2018, 09:18 AM   #7
Tacoma Bob
Tacoma Bob's Avatar
I believe the spring in question is a thin washer made of spring steel.
Tacoma Bob is offline   Reply With Quote
Old 08-17-2018, 12:14 PM   #8
Jwilli
Jwilli's Avatar
I think you are correct, mine don't have that either.
Thread Tools
Display Modes
