Old 12-03-2015, 08:26 AM   #1
imacrazy
Default Heat Shield
Fellows, is advisable to put a heat shield on to protect the distributer, with the manifold heater?
imacrazy is offline   Reply With Quote
Old 12-03-2015, 08:29 AM   #2
2manycars
2manycars's Avatar
Default Re: Heat Shield
I never have used one. The old condensers of years ago would fail from the heat, but the good ones that A&L makes, and the good suppliers sell do not have that problem.
2manycars is offline   Reply With Quote
Old 12-03-2015, 08:44 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I have gotten the A&L condenser hot enough to melt solder, never skips a beat in the heat, been using the same condenser for 25 years, no need for a heat shield
Old 12-03-2015, 11:44 AM   #4
DougVieyra
DougVieyra's Avatar
If I remember correctly (dangerous assumption), the Ford Motor Company in responding to dealer (and owner) complaints, made the DISTRIBUTOR HEAT BAFFLE a Dealer-supplied Authorized accessory, in December of 1929. So at that time, the Ford Motor Company thought the heat baffle might do some good.
Not with-standing that A&L now makes a 'Heat Proof' (resistant) condenser that has removed much of the problem of the original 1920s-'30s type of 'old technology', the accessory 'Heat Baffle' still does some good at deflecting some exhaust manifold heat away from the Distributor's condenser.
It has been a long time since I used one of these 'neat gadgets', so someone might want to help refresh my memory - does the heat shield get in the way of accessing the Distributor 'Oiler' for routine lubrication maintenance of the Distributor ?
DougVieyra is offline   Reply With Quote
Old 12-03-2015, 11:53 AM   #5
Aerocraft
Aerocraft's Avatar
I have been running two Model A's with Autolite "waffle style" manifold heaters and have not had a condenser failure although I have changed them at roughly 10K miles. The heat shield (manufacturer unknown) that I have in my collection, but don't use, will not fit with the manifold heater installed.
Gar Williams
Aerocraft is offline   Reply With Quote
Old 11-27-2017, 02:27 PM   #6
duke36
Only blocks access to the distributor retaining set screw and may require draining coolant to install. Not sure much benefit with the shield and modern points/upper plate.
duke36 is offline   Reply With Quote
Old 11-27-2017, 02:33 PM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
The heater cover acts as a very good heat shield.
Jacksonlll is offline   Reply With Quote
Old 11-27-2017, 04:13 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
The thing I don't like about the distributor heat shield is that the head nuts only come in contact with part of the shield because the hole is open on one side and have very little contact. My Town Sedan came with this heat shield but now resides in my "Spares" drawer.
I suppose you could install a washer but then the nut isn't threaded down all the way.
