07-24-2017, 05:16 PM | #21 |
Re: Think it blew up!
Rich is very good to work with! Call him before driving there, he can and will save you on shipping, sales tax, etc.
07-24-2017, 06:04 PM | #22 |
If your trouble began with no coolant, my guess is as others have suggested, a piston grabbed in a bore. Obviously, the engine was hot. I suggest you have them check the block for cracks while it is apart and don't go cheap fixing it.
07-24-2017, 06:51 PM | #23 |
I have had GREAT results from my ANTIQUE ENGINE -Skokie IL Engine. Maybe 10,000 miles, does 65 mph easy, balanced shaft, touring cam, enlarged intakes, valves, inserts.
I use Mobil One and do not lose a drop between changes. The balanced crankshaft makes higher revs easy without trauma to the engine. |
