12-27-2016, 11:44 AM | #1 |
49-53 ford car oil pan differences
Trying to look at some oil pans for a shobox project. Can anyone confirm/deny the following:
49-51 Ford car oil pans have the "smooth" sides and no "trough" for the oil drain. 52-53 Ford car oil pans have the "dimpled" sides and a revised oil center drain plug "trough". I'm looking to upgrade my steering linkage and apparently only the 49-51 style clears the centerlink. Thanks in advance! |
12-27-2016, 01:34 PM | #2 |
Re: 49-53 ford car oil pan differences
The '49-'51 pans are similar, with center sumps and smooth sides, but the '51 sump is located an inch or so forward of the earlier '49-'50 sump.
The '52-'53 pans have the ribbed sides with sumps similar in location to the '51. All the pans on hand or I've seen have a shallow trough leading to the drain plug. |
12-27-2016, 06:37 PM | #3 |
And I think if you can find a 49-51 Mercury it is a rear sump. I'm sure someone knows the details. I installed a Merc rear sump pan in my 40 when I installed a 8ba.
12-27-2016, 07:55 PM | #4 |
I used a rear sump truck pan on the 8ba in my '39 p/u.
Making the simple complicated for over 30 years. |
12-27-2016, 10:03 PM | #5 |
Toward the bottom of this pdf are some oil pan differences - from the techno page
http://www.flatheadv8.org/bellhousing.pdf edit: the links aren't working for me - used to have an explanation for each picture... sorry Last edited by mtflat; 12-29-2016 at 07:15 PM. |
12-27-2016, 10:14 PM | #6 |
Bob |
12-29-2016, 07:15 PM | #7 |
thanks Bob, must be my laptop...
12-29-2016, 07:20 PM | #8 |
Thanks to all.
