11-06-2017, 07:00 PM | #1 |
1941 ford hood release passanger car
Putting a car back together that someone else partial dismantled for a re wire. The dash was out of the car. I got it back together now and the hood cable is missing all together. For now i am going to use a choke cable.
The question is, is there a bracket that mounts it under the dash? I have a box of odds and ends in the trunk with a couple different style of what looks like dash brackets but could just be aftermarket western auto heater controls |
11-06-2017, 07:51 PM | #2 |
Re: 1941 ford hood release passanger car
Mine has a bracket on the far left of the dash. Goes straight out to clips on inner fender.
11-06-2017, 07:59 PM | #3 |
Does it use the corner bolt that holds the lower corner of the dashboard to the body? This dash has a bunch of extra holes on the bottom flange from previous owners mounting stuff like switches
11-06-2017, 08:55 PM | #4 |
I'll have a look in the morning.
11-06-2017, 11:13 PM | #5 |
On mine the bracket uses a hole about 3 7/8 inches inboard of the one you are referring to; sort of between the start button and the light switch.
11-07-2017, 12:55 PM | #6 |
11-07-2017, 01:48 PM | #7 |
Early model year '41. Replacement Cable and repro dash bracket, but mounted to the hole on the bottom of the dash where the original bracket was.
11-07-2017, 10:24 PM | #8 |
I found this bracket in the trunk, is it for the cable or something else
11-07-2017, 10:38 PM | #9 |
That looks like the original hood pull bracket that was on my '41. It was pot metal and broken. The replacement part I got is unpainted steel and has a slot into the hole, so the knob does not have to come off to get the pull cable through the bracket hole.
11-07-2017, 10:49 PM | #10 |
This one is pot metal and has a D shaped hole for the cable. The mount hole to the dash looks like it might have been drilled out.
11-22-2017, 07:50 AM | #11 |
Got the hood release bracket figured out and the dash back together. The last piece to figure out is the dash brace. I found it in the trunk. I know how the dash brace mounts in a 40 ford but no clue on a 41.
Does anyone have a picture? I did install a newport engineering electric windsheild wiper kit which fits great and works a lot better then the vacuum set up. Hope the brace doesnt interfer with it |
11-22-2017, 07:45 PM | #12 |
Here are some original photos of a Genuine 1941 Ford Hood Pull with bracket and cable. They are some nice clear close-up of the parts so you can see exactly what it looked like.
Bill Monzo |
Thread Tools | |
Display Modes | |
