10-22-2017, 06:27 PM | #1 |
41 ford firewall
I got a 41 ford sedan in for some minor repairs, one being a butchered wiring harness. I need a picture of the firewall mainly on the driver side. The fuel line is not secured and some extra holes from the previous owner.
Neat car overall. Bas a built 49 merc motor and a mitchell overdrive. Less then 1000 miles on the motor. Its a 4dr with a nice body Basically a car that can be driven anywere and left outside. |
10-23-2017, 01:25 PM | #2 |
Re: 41 ford firewall
Here's a pic from my '41 coupe. Let me know if you need more.
10-23-2017, 01:48 PM | #3 |
Thanks for the picture. Were the wiring harness cover is, next to it.
is that the clip to secure the steel fuel line? The picture gets blurry when i try to enlarge it |
10-23-2017, 07:09 PM | #4 |
The screw that retains the clip for the fuel line is directly beneath the innermost regulator mounting screw, below the the angular rib in the firewall and the clip is parallel to the floor.
10-23-2017, 07:43 PM | #5 |
Do you have a clear picture of it? The one above looks like it might be using the same screw for the wire harness cover
10-23-2017, 08:24 PM | #6 |
10-24-2017, 07:57 AM | #7 |
There is a screw hole directly above the steering column and right below the bead in the steetmetal that runs at a 30 degree angle. Is that the one i am looking for to anchor the fuel line?
10-25-2017, 04:27 PM | #8 |
Here is a better picture I hope.
10-25-2017, 06:46 PM | #9 |
Belated response to post #7 yes that is where the fuel line clip is anchored.
