02-24-2019, 08:09 PM | #1 |
Upgraded to 12v Elec, Then No Power
Did a pretty basic conversion from 6v to 12v today.
New 12v battery, 12v alternator, 12v coil, 12v amp gauge, new 12v bulbs. Got the car to fire up after doing the conversion, all seemed well. Started changing the tail light bulbs, got the running lamps working successfully first, then started on the brake lights. During testing the brake lights (unsuccesfully) I lost power. Running lights don't work anymore, turning the key I have no power to attempt to start the car again. Confused. Battery is showing 95% charge. Short circuit somewhere? But why suddenly? Only thing I can think to do is start over fresh on the battery connections to ensure I have a really solid ground and tight connections on the poles. Thoughts? |
02-24-2019, 08:18 PM | #2 |
Re: Upgraded to 12v Elec, Then No Power
Really stupid question on my part but I have to ask. Do you have a main fuse? To lose everything so fast the first thing I thought of.
02-24-2019, 09:51 PM | #3 |
Not a stupid question at all. That's a helpful suggestion I hadn't thought about Ruth. I'm a recent owner of this coupe and I'm not 100% sure about the ins-and-outs of this electrical system. Best I can tell, there is no master fuse. The only fuse on it seems to be the one I installed a while back off the starter. While I had hoped to avoid it, sounds like I may just need to go through the wiring thoroughly.
02-24-2019, 10:24 PM | #4 |
What year is this vehicle?
Did you change from original positive ground to negative ground when you changed to 12 volts? The "master fuse" that Ruth asks about IS the one you installed on the starter a while back.
02-24-2019, 11:02 PM | #5 |
Gotcha Jim. Yes changed from positive ground to negative ground. I eyeballed the fuse at the starter and it looks good. Tomorrow night will change it out or bypass it to rule that out as a factor.
02-24-2019, 11:11 PM | #6 |
I asked what year car this is because the 1928-29 style brake light switches, the reproduction junk that's been sold for the past 20+ years, are junk. Junk. They are prone to shorting out inside. In the process of testing your new stop lights, you may have unknowingly shorted out the junk switch. There are other places for short to occur. They are easy to track down by starting at the point where the wires connect to the generator (alternator in your case). Isolate lighting system from ignition system. Work from there. If you had the instrument panel off (for a 12 volt ammeter -- there is no such thing) you can have a short in there to the gas tank. Be systematic and you will find your problem.
02-24-2019, 11:11 PM | #7 |
Buy or borrow an inexpensive analog (NOT DIGITAL) voltmeter and start looking for voltage where it should be.
Charlie Stephens |
02-24-2019, 11:16 PM | #8 |
Charlie is right.
Or a basic test light where you connect a wire with an alligator clip to ground, and then go around and touch each post, nut, or screw one step at a time -- looking for power where it is supposed to be -- until you don't find it. Here's the one I carry: https://www.amazon.com/Podoy-Voltage...tph_263_lp_t_3
02-25-2019, 09:42 AM | #9 |
Without the fuse the cause would have been immediately obvious from all the flaming wires. Give yourself a pat on the back for installing one.
02-25-2019, 11:51 AM | #10 |
If you install a new fuse and it blows, as other have said stop light switch is a probable cause. To find the real cause get a small 12V bulb and attach alligator clips with wires to the bulb on both the base and center contact. Connect the two alligator clips across the fuse mounting without a fuse installed. If the bulb lights and you have nothing on you have a problem somewhere. You can verify the brake switch if the bulb stays on after depressing and releasing the brake pedal. When the bulb goes off and nothing on, you are good to go.
02-25-2019, 12:04 PM | #11 |
Just because a fuse looks good doesn't mean it is. It needs to be tested, either in place w/a voltmeter or test light, or removed and tested w/an ohmeter.
02-25-2019, 06:58 PM | #12 |
Look around for a master switch and tighten all battery connections. If
02-25-2019, 08:54 PM | #13 |
Do you have power to the starter and can turn the engine over? If you do then it is a good chance the small fuse mounted to the starter is indeed bad. A simple test light is your friend in a situation like this.
Dave / Lincoln Nebraska |
02-26-2019, 09:39 PM | #14 |
Get a test light and start testing for power and grounds .
When I taught automotive tech , I had bulbs I had painted the contacts with clear finger nail polish , really makes them test it all .
Sometimes I want to say ,,You should have bought a Shay. |
