09-19-2019, 04:26 PM | #1 |
40 Ford rear hubs
I am usually on the Model A forum, but I am building a hotrod using a 40 Ford Banjo rear end. One of my hubs is pitted in the bearing race.Is there a sleeve that can be used to fix this hub, or is there some fix short of replacement. Thanks in advance for your information.
Rod .. Midgetracer. |
09-19-2019, 07:45 PM | #2 |
Re: 40 Ford rear hubs
I am not aware of any sleeve system and I will tell you the hub housing, in the bearing area, is VERY difficult to rebore with a cutting tool.
There have been some adaptations of different bearings in the hubs. I think Lawrie on this site listed some info several months ago. A search might turn something up. Finally, how bad is it and how much use is intended?? I have seen some really raunchy bearing bores that had no undesirable affect on the bearing. If you can not locate a better hub a careful exam might be in order. The Ford bearing is wide and apparently can pass over some pitted areas without sustaining immediate damage. |
09-19-2019, 07:49 PM | #3 |
Are you asking about the hub or the axle housing??
09-19-2019, 08:07 PM | #4 |
If it's the hub, you can buy new re-pops. https://www.speedwaymotors.com/Speed...5-BP,8333.html
09-20-2019, 08:14 AM | #5 |
I'm wondering the same thing. Usually the bearing race on the axle housing (integral to the axle housing) is pitted.
If that is the case you can buy a new race, have your axle housing machined down and press on the new bearing race. Let us know specifically what you are speaking of. |
09-20-2019, 08:33 AM | #6 |
09-20-2019, 10:33 AM | #7 |
