05-03-2019, 01:33 PM | #1 |
Battery Cutoff Switch in 29 Model A
Installed "battery cutoff" switch cuts off A starter button but not engine when running. This is not wired correctly, correct?
Uploaded image of type switch. |
05-03-2019, 01:49 PM | #2 |
Re: Battery Cutoff Switch in 29 Model A
Not wired correctly. Switch is typically put in the frame to battery post cable/connection, or in the other cable coming out of the battery. Can not be more detailed, do not know if you are running positive ground or negative ground.
05-03-2019, 03:56 PM | #3 |
Thanks. Stock positive ground.
05-03-2019, 04:58 PM | #4 |
It should be in the ground cable irregardless of whether it's positive or negative ground.
05-03-2019, 07:28 PM | #5 | |
Joe K
Shudda kept the horse. |
05-04-2019, 10:32 AM | #6 |
05-04-2019, 10:51 AM | #7 |
Thats why I will run this FIA approved cutoff switch:
https://www.pedersenracing.no/butikk...ombryterpakke/ This Will cut my coil from it's power source and give my alternator some resistance to work against until it comes to a stop. Rune Waltoft from Norway |
05-04-2019, 12:51 PM | #8 | |
05-04-2019, 09:19 PM | #9 | |
Learned something new, when using a kill switch on a running A the gen will keep the motor running. |
05-06-2019, 11:33 PM | #10 |
Not a good idea. Kill the engine, then open disconnect. With engine running you wont get regulation from the battery, if you increase RPM voltage will go very high. Tough on bulbs etc.
