06-26-2018, 03:20 PM | #1 |
Domed Engine Heads
Is it possible to use domed heads on a flathead that has flat top pistons? If
so what problem(s) may be created in doing so? |
06-26-2018, 03:23 PM | #2 |
Re: Domed Engine Heads
Low compression.
06-26-2018, 03:24 PM | #3 |
I would say lower compression....
06-26-2018, 04:10 PM | #4 |
I just corrected this situation on a 1935 Ford that a friend bought. Lower compression as the other fellas have said.
06-26-2018, 05:25 PM | #5 |
Mine is the other way around.
Domed pistons with early flat top piston heads. Am running 2 head gaskets ATM, until one day when it needs to be overhauled. |
06-26-2018, 05:43 PM | #6 |
Cheap go fast. |
06-26-2018, 06:09 PM | #7 |
Thanks everyone for your responses.
Peter |
06-26-2018, 07:21 PM | #8 | |
Spill the secret Pete...
06-26-2018, 09:40 PM | #9 |
It is no secret. It is just a matter of Boyle's laws of physics.
When you compress a gas into a container (combustion chamber), the smaller the container, the higher the pressure for a given amount of input energy. Two mating flat surfaces have less area than two mating curve surfaces for the same diameter. |
