10-19-2017, 12:12 AM | #1 |
Challenge Tightening Red's Headers
I've got Red's Headers for my B Block, an A/B Kit, and I'm running a Weber carburetor. I can't seem to find a wrench that I own, or don't own, to get the inside 11/16 nuts manifolds to block tight. The outer two I can tighten with a 11/16 socket.
Any experienced members out there that can suggest a wrench or tool that will fit to tighten the two inner nuts? Thanks! 20141211_220048.JPG[ATTACH][ATTACH]IMG_3838.JPG[/ATTACH][/ATTACH] |
10-19-2017, 12:25 AM | #2 |
Re: Challenge Tightening Red's Headers
I have a couple of 'flex' extensions with a ball-like end that allows a 15deg misalignment. Looks like it would get around that inner header tube.
Fearless |
10-19-2017, 07:29 AM | #3 |
Replace them with Allen head bolts so that you can use an "L" wrench to tighten them. Don't worry about trying to achieve published recommended torque values with a torque wrench. Just snug the bolts down a couple times until the gaskets compress completely.
Marshall |
10-19-2017, 07:51 AM | #4 |
1929 Model AA - Need long splash aprons! |
10-19-2017, 07:56 AM | #5 |
buy a smaller nut as in 12 point
10-19-2017, 08:51 AM | #6 |
No restorable Model A's were harmed in the building of this truck! |
10-19-2017, 08:52 AM | #7 |
Starter wrench, combination wrench bend to fit. Thats the fun part of being a mechanic! finding a way to tighten fasteners :-) or remove!
10-19-2017, 09:24 AM | #8 |
I agree with Big hammer.
I stop at pawn stores and purchase cheap wrenches of varying sizes and then heat them up and bend them as needed for particular needs. I keep a box of the pawn finds in my shop ready for modification. I don't think I have more than $40 invested in a pile of them. It's a cheap alternative to expensive specialty tools. Good Day |
10-19-2017, 10:10 AM | #9 |
I used bolts made for headers. The hex head is 7/16 then it is full size under the hex to fit the header.
10-19-2017, 10:52 AM | #10 |
Try using a flanged nut with a smaller wrench size. Similar to header bolts as George mentioned (i think ).
10-19-2017, 10:58 AM | #11 |
Thanks all!!!!!
10-19-2017, 08:37 PM | #12 |
Bench grinder and hot wrench modification.
