Old 09-14-2017, 03:30 AM   #1
Charlville
Charlville's Avatar
Default Odd pipe in oil gallery, any ideas please?
Just pulled the tappet cover off to fit an oil filter kit and where the pipe is to be located for the oil filter feed a pipe has already been fitted and is pointed down into the timing cover. Now maybe it had an oil filter kit fitted previously or there were oiling issues? Either way I want to remove the pipe to fit the pipe for the oil filter kit. But now worried that I may cause an issue by doing so. Car has a Simmons Power Head not sure if this makes any difference?
Thoughts welcome please
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 09-14-2017, 06:31 AM   #2
john charlton
john charlton's Avatar
Default Re: Odd pipe in oil gallery, any ideas please?
The only thing I can think of is to channel more oil flung off the timing wheel to the main bearing feeds . .I hope it is well secured so it doesnt get eaten by the timing wheel ,I would remove it as IMHO the benefit would be minimal .
John in dreary cool wet where is Mr Sunshine Suffolk County England.
Old 09-14-2017, 07:18 AM   #3
kenparker
kenparker's Avatar
possibly tube to a once in history external oil filter.
kenparker is offline   Reply With Quote
Old 09-14-2017, 07:53 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
Think when you drop the pan you will find the pipe goes to the mains as a homemade pressure to the mains--- look in the valve chamber to see if the oil feed pipes are blocked off
Old 09-14-2017, 11:05 AM   #5
Charlville
Charlville's Avatar
Hi All
Thanks for the all the inputs.
Removed the offending pipe and fitted the oil filter kit, all seems well (so far)
Kevin Flood
West Berkshire UK
Old 09-14-2017, 01:52 PM   #6
Bob-A
Bob-A's Avatar
Thumbs up Re: Odd pipe in oil gallery, any ideas please?
Mr. Flood,
Can you display a couple of pics of your Simmons Power Head.
I've got one that I'm hoping to put on a car in the near future, I hope.
Bob-A
Bob-A is offline   Reply With Quote
