02-15-2018, 10:45 PM | #21 |
Re: Switching to juice brake question
Also check on 49 to 56 Ford half ton front brakes. I have them on my 40 and they work well. Check on the barn for information.
02-16-2018, 01:39 AM | #22 | |
02-16-2018, 07:44 AM | #23 |
He gives good advice and makes nice products. Sounds like you have a good plan.
John |
02-16-2018, 08:44 AM | #24 |
You WILL be happy with the MT products. I used them on my coupe and am in the process of fitting them to my '35 pickup. Good stuff!
Do I look like I have a plan B? |
02-16-2018, 08:52 AM | #25 |
Richards stuff works..!!! Don't go with Speedway...!!! It will cost you more in the long run when you find out..!!!
02-16-2018, 09:28 AM | #26 |
http://www.aircraftspruce.com/catalo...clickkey=73878 |
02-16-2018, 09:30 AM | #27 | |
02-16-2018, 10:38 AM | #28 |
Front discs are wonderful. The Lincoln brakes are very good as well. I have disc on front and lincoln on back for 36 and 41. The Lockheed brakes can be made to work but are way more work than the others. IMHO the F100 brakes from the 50s are better than the lincoln brakes in that they are self adjusting. Rich B a barner restores and sells them and cheaper than lincoln as well. I sold him a set to recondition that was on a 40 Ford. I am not the author of the he stuff posted on my website about F1/F100, I found it here on the barn and liked it enough to save it so I could refer to it in the future. I also concur to stay away from silicone fluid. https://fordbarn.com/forum/showthrea...ghlight=brakes https://fordbarn.com/forum/showthrea...ghlight=brakes
More about F1 brakes: https://mrtexascitrus.weebly.com/f1brakes.html Here is what I used: https://mrtexascitrus.weebly.com/earlyv8discs.html
41 woodie https://41fordwoodie.weebly.com/ Last edited by mrtexas; 02-17-2018 at 10:03 AM. |
02-16-2018, 12:38 PM | #29 |
I use a single Mustang Master cylinder on my 32 Tudor. The front brakes are Lincoln type from Richard @ Early V8. The rears are Ford 9" axle brakes that are self adjusting.
If I ever get the energy I will make the Lincolns self adjusting, as well. I use Dot 5 fluid with no leaks. JMO Jim |
02-16-2018, 02:50 PM | #30 |
mrtexas I like the idea of cheaper better with the ‘50’s F100 backing plate kit. Will they work on my ‘35? Where to get & all parts required. Hubs drums bearings etc. does Rich B put a complete kit together or do I have to accumulate mix & match on my own?
Nomad |
02-16-2018, 03:43 PM | #31 |
I'm a big fan of the F1 and F100 conversions. Believe Speedway sells the bearings, etc. Fairly sure you need to come up with the Spindles, Backing Plates, Drums, etc on your own. If someone on the Barn sells the parts as a kit, that would be an easier way to go! All of the guts (wheel cylinders, brake shoes, hardware, etc) is available anywhere and are the same parts used on a number of different cars over many years. I can provide you all of the part numbers if you need them. The Backing Plates, Hubs and Spindles are going to be the hardest parts to find I would guess. Drums should be easy.
I far as I know you need 37 or later Spindles. Here is some background info if you are interested. Last edited by JSeery; 02-16-2018 at 03:52 PM. |
02-16-2018, 03:55 PM | #32 |
F-1/F-100 brakes won't readily work with your original '35 wires (unless you like thick spacers).
They can be installed on 35-36 spindles using the centering ring out of the common kit used to fit Lockheed brakes to the earlier spindles and dealing with the mount holes by which ever method you prefer. |
02-16-2018, 04:05 PM | #33 |
Thx J, it looks like Rich B a Barner can supply rebuilt backing plates with wheel cyl's & all parts related to just the face plates. '37plus spindles easy. the PDF file is very helpful for the rest.
Nomad |
02-16-2018, 04:08 PM | #34 |
02-16-2018, 04:16 PM | #35 |
Agreed... Early Ford Store has the M.T. brakes!
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
02-16-2018, 04:22 PM | #36 |
Are the hubs F100 specific or the same as used/supplied via M/T & others for the Lincoln bendix setup? Will I lose the 5 on 5 1/2" wheel pattern?
Nomad |
02-16-2018, 04:35 PM | #37 | |
The F1/F100 is 5 x 5 1/2, I don't know anything about the MT setup, but would think they would also come 5 X 5 1/2 as it is a commonly used wheel size. |
02-16-2018, 04:47 PM | #38 | |
You need to pay attention to the minor (yet IMPORTANT) differences between F1 and F100 hubs. The difference moves the drum inboard OR outboard in relation to the brake shoes/backing plate. Click on and study the link below. It's easy to get in over your head on some of the details with these kinds of swaps. Pay attention to the folks that have details on a complete, functioning system, and above all, DON'T go with some parts just because you've heard the name a few times. See the pic below for some F1/F100 differences. One more thing.....Just because you have a 5-1/2" bolt pattern does not NECESSARILY mean that your '35 wire wheels are good to bolt-on! DD |
02-16-2018, 05:35 PM | #39 | |
From Rich B. FB member and re-builder on these
I did know about the the '35 wire rims needing the spacers not to deform the rim with other than the '35 drum / hub ( any other issues you where thinking? ). I believe the combination I need is '37 plus yr spindles, F100 hubs the 5 0n 5 1/2" wheel pattern for drums seems to be used on F1's and F100's? I'll check on the diameter of the front of hub to make sure the nut flange doedn't interfear with the hole to accommodate in the rims.
Nomad |
02-16-2018, 05:42 PM | #40 |
Believe Ford used 5 X 5 1/2 on F100s up into at least the 80s.
