Old 09-25-2019, 09:11 PM   #1
thom
thom's Avatar
Default LH park brake handle repair
The spring is either broken or missing from the park brake handle on our "new" '28 coupe. I have to move the squeeze handle manually in order for it to latch in place. I believe someone has had it apart before because the two parts are together with a bolt and nut instead of a rivet. I have not found a listing in the vendors catalogs for a spring. When I take it apart maybe I can find something at the hardware store?
thom is offline   Reply With Quote
Old 09-26-2019, 03:26 PM   #2
SwampLedge
Default Re: LH park brake handle repair
Check at www.Snydersantiqueauto.com for p/n A-2711
SwampLedge is offline   Reply With Quote
