Old 05-18-2018, 08:12 AM   #1
oldskool
oldskool's Avatar
Default electric wipers 40 pickup
my 40 pu has a single non working wiper and I see speedway sells a universal electric wiper anyone using one in a 40-47 pickup pros and cons.thanks p/s truck has 12v system
oldskool is offline   Reply With Quote
Old 05-18-2018, 08:17 AM   #2
Krylon32
Default Re: electric wipers 40 pickup
For a really good wiper setup I would spend some extra money and get the wiper kit made for your truck from Newport Engineering.
Krylon32 is offline   Reply With Quote
Old 05-18-2018, 01:28 PM   #3
oldskool
oldskool's Avatar
it would be great if they made one for a single wiper system but presently they do not...thanks
Old 05-18-2018, 04:52 PM   #4
alanwoodieman
I did a dual wiper conversion on a 41 cab, had to cut the glove box down by half to put the wiper on ps. I think this one came from carpenter or drake. If I had to do over again I would not.
Old 05-19-2018, 07:03 AM   #5
TJ
TJ's Avatar
Take a look at the one made by Mighty Wiper made by Pacific Western Design.
Old 05-19-2018, 12:52 PM   #6
Roger/Sacramento
Roger/Sacramento's Avatar
I got the item from Drake and eliminated the arm that would go through the glove box. So only the driver side works. Doesn't matter because I never put wiper blades on anyway.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 05-20-2018, 06:56 PM   #7
russcc
Rebuilding an original vacuum wiper may be a simple solution. Kent at Clean Sweep in Redmond OR did one for my '40, and it works great.
Old 05-20-2018, 07:27 PM   #8
41ford1
41ford1's Avatar
I used a Speedway unit in my pickup. It works well when I need it. I set it up to stop when the switch is turned off. I like it parked at the cowl. If the built in park feature is used it will park against the center windshield bar.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 05-21-2018, 08:10 AM   #9
TJ
TJ's Avatar
I did the same on my '41 pickup. Couple that with a little Rain X and it works like a champ.
